Going to install DC Headers
Old Aug 14, 2001 | 06:20 AM
revhard's Avatar
Default Going to install DC Headers
Just wanted to know any good tips on the install. I ordered a new gasket and bung ring to replace. What do I need to be careful of or buy before the install? Any help would be GREAT! thanks
Old Aug 14, 2001 | 07:13 AM
gregstevens's Avatar
Banned
The hard part is getting the stock heat shield off. The black one between the battery and the manifold takes some maneuvering, as there is a bolt near the firewall that has to come out. I wish I could remember the specifics how we got mine off, but just get creative and it will work. Get new bolts for the header
Old Aug 14, 2001 | 01:09 PM
tims2k's Avatar
You can use the factory gaskets if you wish to do so, my install took about 2 hours and be careful when pulling the factory header out.
Let me know when it's done, I enjoy my header!!!
Also not remove the blk heat sheild first them remove the factory heat sheild from the header and there are the bolts from the bottom and I think 6 from the top, not sure though someone else did my install I just watched.
Old Aug 14, 2001 | 01:31 PM
S2K_LA's Avatar
About how high off the ground does the car need to be? Could this be done with jackstands or is a lift a must?
Thanks
Old Aug 14, 2001 | 01:36 PM
mingster's Avatar
a lift would be perfect of course, but jacking it up on all fours will be ok too.
Old Aug 14, 2001 | 01:38 PM
tims2k's Avatar
I done my instal;l with two jackstands and one really big 6 ton jack.
kamui157
Nov 17, 2008 05:21 AM
Defender
Jul 31, 2005 08:36 PM
hunghid
Nov 1, 2003 01:17 PM
Freakaccident
Aug 26, 2002 11:35 PM
johnR
Oct 16, 2001 03:07 AM
