Ground wire kit
Old Jul 29, 2005 | 04:59 AM
thats_mr_2_u's Avatar
Default Ground wire kit
I was just curious if anyone knows if the ground wire kits you buy that supposedly adds horsepower... I know it "supposedly" works, in theory....but does it work in Real life...and does anyone have them in there car?? Just tryin to figure out whats worth buyin....other than FI that will add hp
Old Jul 29, 2005 | 05:05 AM
DiamondDave2005's Avatar
Forget it - waste of money.
Old Jul 29, 2005 | 05:13 AM
hygiene boy's Avatar
Don't pay $100 or more for a pre made kit. You can make your own for $15 or less.
It may smooth out a rough idle and that's about it. On a relatively new car with a good ground already don't expect miracles. I have one on my turbo VW and it makes the engine run smooth and it fixed my headlight dimming problem but no noticeable power increase. Buy 3 or 4 negative battery cables from your local auto parts store($3 each) They come in various lengths in black 4 gauge copper wire with connectors already on. Connect them in a daisy chain fashion to various points around the engine bay. For example: Start from the nut atop the driver's side shock tower, then go to the engine block, then to the firewall and finally connect to the negative battery terminal. It's that simple.
Old Jul 29, 2005 | 05:26 AM
energetic's Avatar
Easy as that!
Old Jul 29, 2005 | 05:38 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Old Jul 29, 2005 | 06:20 AM
dat s2k's Avatar
most people say the only benifit it helps with is A/C lag
Old Jul 29, 2005 | 08:42 AM
aklucsarits's Avatar
Ground is ground. An electrical circuit is either grounded or it's not grounded. All the fanciest, most colorful wires in the world cannot make an electron behave any differently!
Andrew
s2000adventures
Aug 31, 2022 08:33 PM
liquidgsr
Dec 6, 2011 05:16 AM
nMeOnE
Jan 28, 2007 05:15 AM
sleeze
Aug 29, 2006 09:36 PM
ajkewler
Apr 30, 2004 06:56 AM
