"H" and "S2000" emblem shaving?
Old Sep 3, 2003 | 01:13 PM
CarbonFiberLip's Avatar
Default "H" and "S2000" emblem shaving?
Just ordered "S" emblems from Rick's and wanted to know who has any info on what is going on under the stock emblems... two holes and two sided tape? Do you heat that stuff up good before removing them? Are the side "S2000"emblems mounted the same as "H" on front and rear? Thanks! Carbon Fiber Lip
Old Sep 3, 2003 | 01:22 PM
Gunshow's Avatar
The emblems can be safely removed with the same method you use to floss. There will be pegs for the Honda emblems, but none for the S2000 on the side. If you have a lot of 3M tape on the body after removal then you can use different solutions like Orange Glow, Windex, Simple Green... I would rather use a safer adhesive remover and clean the area after with soap and water to make sure that once the Rick's stuff goes on then it will hold better.
Old Sep 3, 2003 | 01:27 PM
Thanks R-tistik s2k... Should I do this with the emblems heated up to loosen the tape? and what did you use for "floss"? By the way are you an Artist? cuz I am, CFL
Old Sep 3, 2003 | 01:55 PM
beanolo's Avatar
"dental floss"
and a whole buncha glue gone. or was it goo gone..
Old Sep 3, 2003 | 01:58 PM
3ngin33r1's Avatar
The badges you ordered from Rick's will come with detailed instructions on how to remove the "H" emblems. If you don't want to wait, there is a PDF file for download on the "Installation" section of their website.
Old Sep 5, 2003 | 06:52 PM
So R-tistik are you saying if I remove the "S 2000" emblems on the fenders there will be NO need to fill holes? Thanks, CLP
Old Sep 5, 2003 | 08:12 PM
AP1_rock's Avatar
yes, that's what he is saying
D
Old Sep 5, 2003 | 10:11 PM
4Motto's Avatar
CF -
You've got PM
jkelley
Jul 30, 2014 08:35 PM
u8myrice
Mar 7, 2009 03:34 PM
andykim7
Feb 5, 2007 05:43 AM
tenaciousFD
Oct 24, 2005 03:02 PM
mhs2k
Dec 24, 2004 10:54 AM
