Hardtop loose
Old Jun 4, 2018 | 11:16 AM
Imolaa's Avatar
Default Hardtop loose
Hey everyone, my forbidden hardtop is loose on the back right under the rear window. When im driving and hit bumps it goes up and down and you can see straight outside the car, and i can even lift it up with my fingers a little bit. Is this normal with this hardtop or should it been very tight in that area? I didn't have this issue until i took my car to a bodyshop and they had to remove the hardtop to work on one of the rear panels. Any help would be appreciated, thansk guys.
Old Jun 4, 2018 | 12:03 PM
Scigheras's Avatar
What kind of mounting kit did you use?
Old Jun 4, 2018 | 12:27 PM
Imolaa's Avatar
It came installed with the car, so im not 100% sure but the brackets look like forbiddens basic street brackets and latches seem to be oem
Old Jun 5, 2018 | 07:26 AM
P-Dub's Avatar
It should be very tight in that area, did you put downward pressure on the top while tightening the bolts?
Old Jun 5, 2018 | 05:06 PM
Nfinitecc's Avatar
Don’t wanna sound rude but it should be obvious that you shouldn’t be able to lift the top off with your fingers. I mean it’s either bolted down or it isn’t...
can you post a picture?
Old Jun 5, 2018 | 09:12 PM
Imolaa's Avatar
I did not give downward pressure when bolting it on, ill try that.
Old Jun 5, 2018 | 10:08 PM
Nfinitecc's Avatar
Even if you bolted it down with your fingers in between the top and the car it still shouldn’t be bouncing up and down over bumps or pull up with your fingers.
Old Jun 6, 2018 | 11:14 AM
Scigheras's Avatar
I guess it depends on what you classify as "lifting with your fingers".
My forbidden mugen rep is bolted down tight too, but if I pull up on it hard right in the middle of the back, it definitely flexes up a noticeable amount and can create a visible gap from the chassis.
Old Jun 6, 2018 | 02:55 PM
Nfinitecc's Avatar
Yeah I could see flexing it with the force of your hand and making a gap, but I doubt bumps in the road flex your top to where it opens up gaps. His description makes it sound like it’s not tightened down at all and sliding on the bolts. A pic would help, hopefully holding it down will fix it up.
Old Jun 8, 2018 | 05:07 AM
WheresJc's Avatar
Make sure all the bolts are tight in the rear. The ones that hold the top to the bracket and the ones that hold the bracket to the chassis of the car.
DaGou
Apr 13, 2018 09:28 AM
Trunkz
Dec 8, 2014 12:38 PM
Ian_jobson
Sep 25, 2013 06:02 PM
nikkotheone
Sep 7, 2011 12:23 AM
S2002
Sep 26, 2002 05:11 AM
