headlights
Old May 5, 2002 | 04:12 PM
s2k8oi's Avatar
Default headlights
Can somebody tell me if u have to change the whole headlight to have clear corners or just take the piece off?
Old May 5, 2002 | 04:15 PM
Kwando's Avatar
Save some money and clear them out yourself.
Old May 5, 2002 | 04:17 PM
s2k8oi's Avatar
is it hard and how?
Old May 5, 2002 | 04:22 PM
s2000guy's Avatar
Click below on how to clear them:
https://www.s2ki.com/forums/showthread.php?...lear+headlights
Old May 5, 2002 | 05:08 PM
Fastrack's Avatar
What ever you do don't skimp on the sealer when you put the lights back together. I did and had to pull them out a second time to do the job right.
Nothing will pi$$ you off more than finding them fogged on the inside
Old May 5, 2002 | 05:59 PM
Utah S2K's Avatar
This is the definitive link in clearing your corners....thanks Arnell! Matt 25 and I did mine as noted here. On the second light we upped the time to 15 minutes at 225 degrees and it was A LOT easier. The wet towels will introiduce some moisture....solution. Leave your HIDs on (car at idle) for about a half hour with the turn signal bulds out. This will allow any moisture to escape......worked for me. I keep wondering if these guys that pulled their lights apart a second time tried it? The HID's are hot and the moisture will drive off if you give it a chance and an escape route.
Utah
P.S. Thanks Arnell!!!!
trick408
Feb 12, 2006 06:31 AM
Sub-Zero
Feb 13, 2003 02:01 PM
LordMagnet
Jan 26, 2003 08:57 AM
BlackRoseS2000
Nov 26, 2002 09:11 PM
