Heat wrap for intake?
I still thought the price was to high so I used a custom vaccum hose about 2 inches that is attached to the front grill
Its like AC coming thoughr when you blow and stick it out the window for tests, so at high speeds I'm sure lots of cold air is coming though!!
nice I also took that bonnet piece off since it owukd have intefeered with the hose coming in and fitting nicely without the hood smashing it. I didn't even do any cutting, it fitted smotholy and snaked through an opening on the side, I didnt want to cut anything up near the radiator.
Let me get this straight: you guys are wrapping the OEM rubber hose?
Why? I think it is very well insulated for heat already. I'm sure engineers took heat into consideration already. I didn't see a need for heat-shield wrapping. I only did it to a CAI, which is made of aluminum, which is prone to heat.
Again, I don't see why heat wrapper is necessary for an OEM rubber pipe.
Why? I think it is very well insulated for heat already. I'm sure engineers took heat into consideration already. I didn't see a need for heat-shield wrapping. I only did it to a CAI, which is made of aluminum, which is prone to heat.Again, I don't see why heat wrapper is necessary for an OEM rubber pipe.
Why?
Why?
I was checking out xviper's temp narrative when I considered heat wrapping my engine. The rubber intake tube was the easiest part to wrap and the closest to heat sources.
I'm looking for some flexible mesh to cover the shiny wrinkled heatwrap and make it more presentable.
Boy, does Thetz99's cut up snorkle look like what Spoon did to their S2000 in 2004...where the snorkle does not appear to go to the intake, but rather to to the engine compartment just in front of the intake!
-Justin
-Justin
I bought a thermo-tec wrap for my intake... It looks like a little corset for your intake
It seems pretty heat resistant and its really easy to install.
I got mine from here: http://store.yahoo.com/racingsuperstore/coairtush.html
It seems pretty heat resistant and its really easy to install.I got mine from here: http://store.yahoo.com/racingsuperstore/coairtush.html
