help please! hard top question..
Old Sep 15, 2005 | 08:17 PM
onani's Avatar
Thumbs up help please! hard top question..
I own a 2003 GPW S2k and I would like to buy a hard top for my S2k from a 2001 Yellow S2k (limited edition). My question is will the 2001 hard top that comes with the installation kit fit my 2003 S2k? or I have to purchase a installation kit for 2002-2005??
The reason why I ask, cause I found 2 of the following items in hardtopguy.com
2000-2001 Hardtop installation kit
2002-2005 hardtop installation kit
please help!
Thanks
Old Sep 16, 2005 | 04:42 AM
Poindexter's Avatar
You will only need to buy a different kit if you want the rear window defrost to work on the hardtop.
Old Sep 16, 2005 | 06:25 AM
Stratocaster's Avatar
I bought a used top from a MY01 owner and I own an MY02. I ended up with everything working and spare parts. That is because the MY02+ (That includes 02,03,04,05,06) have the defroster wiring from the factory. So assuming that you get all the parts he had installed in his car for the HT. YOu will install it on yours, and test the Defroster. If it works, then you are golden. If it does not, you will need to change the rear catcher on the driver side. I tought I would have to, but everything worked once installed on my car. Honda updated the wiring and rear catcher some time in 02. So if the top was purchased after the change, you will be set.
Good luck
Old Sep 16, 2005 | 10:56 AM
michael ferguson's Avatar
Everythings exactly the same, but, as stated if you want to use the heated rear window, youll need to buy the wiring kit for the switch
Old Sep 17, 2005 | 12:20 AM
WyattH's Avatar
Can you buy the wiring switch seperately?
I have a 2001 with a hardtop from an 03. The catchers worked fine and I bought the strikers, but of course I have no connected defroster. Can I buy these parts seperately? I have the 03 catchers, so it seems I have the harness in the rear, but no button anywhere?
Velvet99
Aug 20, 2015 04:48 AM
Dan J
Nov 2, 2010 12:34 AM
BELGIUMPAUL
May 4, 2005 09:09 AM
FIZZ-AP1
Feb 11, 2005 02:22 PM
newsguy
Aug 12, 2004 09:49 AM
