help with Voodoo knob!
ok so i have a Voodoo knob i bought from ricks site. and i installed it and love it. my problem is on really spirted drives when i shift really hard sometimes the knob starts to spin off meaning it comes loose and i have to stop and rear tighten it.
does anyone have any ideas to help keep it tight? i was thinking lock tight but i don't want it to ruin my knob. any ideas are welcome thanks! jonathan
that was my original thought was the loctight . i'm not using the stock nut never have. i was just worried that the loc tight would make it impossible to get off . thanks for all the help
I got one from Rick couple of weeks ago and love it! Although, I don't have the problem about it getting loose.
You might wanna try to install it when it's cold, twist it the most you can and repeat 3-4 times, do this again while driving or after it gets hot. Most important, make sure you give the tread on the shaft a really good clean, wipe off, so you have a good contact surface. I also did modify the shift boot a bit to sit lower( expose the shaft about 2 inches below the knob base), 'cause I hate the feel of grabbing half metal knob-half soggy shift boot.
I don't want to put any glue on it either, if I have a choice. Try this method, I hope this help.
