help with Voodoo knob!
Old May 29, 2003 | 04:48 PM
BlueS2000Boy's Avatar
Default help with Voodoo knob!
ok so i have a Voodoo knob i bought from ricks site. and i installed it and love it. my problem is on really spirted drives when i shift really hard sometimes the knob starts to spin off meaning it comes loose and i have to stop and rear tighten it.
does anyone have any ideas to help keep it tight? i was thinking lock tight but i don't want it to ruin my knob. any ideas are welcome thanks! jonathan
Old May 29, 2003 | 05:44 PM
Red Blur's Avatar
Look under the knob and you'll find the counter nut...tighten that nut and you'll be all set.
Old May 29, 2003 | 05:58 PM
are you talking about the stock counter nut? i thought you are not suppost to use that because then the knob doesn't sit as low as it should?
Old May 29, 2003 | 06:05 PM
psyco6string's Avatar
Locktite and some muscle is all it takes !!
Old May 29, 2003 | 06:07 PM
Rick Hesel's Avatar
Former Sponsor
[QUOTE]Originally posted by BlueS2000Boy
[B]are you talking about the stock counter nut? i thought you are not suppost to use that because then the knob doesn't sit as
Old May 29, 2003 | 06:10 PM
that was my original thought was the loctight . i'm not using the stock nut never have. i was just worried that the loc tight would make it impossible to get off . thanks for all the help
Old May 29, 2003 | 06:53 PM
Red Blur's Avatar
my bad...i assumed all knobs would use the same nut.
Old May 29, 2003 | 07:08 PM
RM 4 2's Avatar
I got one from Rick couple of weeks ago and love it! Although, I don't have the problem about it getting loose.
You might wanna try to install it when it's cold, twist it the most you can and repeat 3-4 times, do this again while driving or after it gets hot. Most important, make sure you give the tread on the shaft a really good clean, wipe off, so you have a good contact surface. I also did modify the shift boot a bit to sit lower( expose the shaft about 2 inches below the knob base), 'cause I hate the feel of grabbing half metal knob-half soggy shift boot.
I don't want to put any glue on it either, if I have a choice. Try this method, I hope this help.
RXM9600
Jun 22, 2013 08:11 PM
McS2K
Aug 25, 2006 10:05 AM
Purple Haze
May 25, 2005 01:35 AM
koala
Oct 4, 2004 10:58 AM
celicass22000
Nov 27, 2001 11:08 PM
