High Beam Replacement...
I replaced my high beams a few weeks ago. You do not need to take off the bumper but it's a tight fit. On the driver's side, you'll need to lift and move the coolant reservoir. I did it mostly by feel. First remove the wire harness. Then remove the rubber grommet. Then open the "wire lock" that holds the bulb in there. The bulb should come right out after that.
You guys that take off the front bumper to change a high beam bulb, do you also use a 10# sledge hammer to pound in a finishing nail?
Those two holes behind each headlight is there for a reason ............ It's so you can reach in and change your headlight bulbs! The driver's side requires that you lift up the coolant reservoir and place it off to the side so you can access the hole.
Oh, please don't tell us you take the doors off the car to change radio speakers.
BTW, I've changed highbeam bulbs through those holes on 3 cars now.
Originally Posted by LINESUPER,Jan 17 2006, 11:40 AM
well I don't think you can reach all four bulbs through it and those HID bulbs are very sensitive to dirt, grease etc.
Just bought new high beams for my S
taking the bumper off may seem "easy" to some.... but I'd have to say, what I don't like about taking the bumper off is the chance that it could get scratched AND the fact that you have to deal with re-aligning the damn thing afterwards. It is a total PITA.
what I would do if I really couldn't get my hands in there would be to just jack the car up, remove the wheel, and remove the inner fender. 5 minutes and you have complete access to the back of the headlight, unobstructed. Also a great way to align your bumper with it on the car if you are having issues...
Originally Posted by .no tork.,Jan 17 2006, 06:58 AM
Once you have the headlight out it's simple and self explanitory. I replaced my highbeams with BlueZone 100watt 4200k Halogen bulbs last week, definately brighter and they match the HID's. Taking the bumper off was easy, even being my first time and without a manual. The headlights were simple as well, but I had to refer to a service manual I found on here. All in all it was a worthwile mod...not because I replaced my bulbs, because I learned how to take my bumper and headlights off in the process which is always good.
Today I'm going to attepmt the suspension
according to the service manual you remove the front tire ...
I've not done this (although I'm thinking about whiter bulbs) due to the big-hand problem, though. But reading these responses has me encouraged.
And I guess, based on xviper's comments, I don't need to pull the engine to do an oil change, eh? HPH
You know what? All this misinformation needs to be straightened out now.
I just scanned every page in the Helm service manual on this topic.
You go through the wheel well ONLY if you are servicing the HID bulbs.
You take off the front bumper ONLY if you are removing the headlight assembly.
For replacing the high beam bulbs only, as per your OWNER'S MANUAL ..................................
You access via the hole behind each headlight from the engine compartment. For the side with the coolant reservoir, you lift the reservoir up and place it off to the side so you can use that access hole.
If you listen to some of the crap that's been posted here, YES, YOU MUST PULL THE ENGINE TO DO AN OIL CHANGE!
OK, can we get back to our regularly scheduled programming?
