How critical is valve retainer replacement AP1
Old Feb 8, 2019 | 09:01 AM
  #31
roel03's Avatar
I went 4->2 at Sebring and bent 3 valves in my AP1 and cracked 5 retainers. Car shut off immediately. I then bought an AP2 head from ^^^ (S2000Junky) and the car was running 2 weeks later.
Old Feb 8, 2019 | 09:05 AM
  #32
s2000Junky's Avatar
Lucky, in 2 ways
Old Feb 8, 2019 | 01:15 PM
  #33
Mr.Matchbox's Avatar
Originally Posted by s2000Junky
Fair assessment.
I will add my own, which is the ap2 retainers in this scenario would seem more likely to hold on to the valve stem and bend a valve vs crack the retainer and drop a valve. Both suck, but one scenario the bottom end can survive. Id much rather pull the head and replace a bent valve then lose the entire engine.
And thats the point. To me, that is reason enough to switch the retainers.
Old Jun 23, 2022 | 08:08 PM
  #34
HondaOwnerForLife's Avatar
Originally Posted by czirrfb3
I was under the impression the cracking is at the bottom and simply taking the valve cover off wont show any potential damage you would need to remove the retainers to check and at that point might as well replace. But I am not sure that is accurate information.
That's what my mechanic said, pretty much word for word.
Old Jun 24, 2022 | 06:01 AM
  #35
rpg51's Avatar
True that the retainer cracks appear on the bottom side of the retainer and cannot be directly visualized without pulling it all apart. But, you can definitely inspect the retainer condition from the top because there will be obvious visible signs from the top. If a retainer is cracked the stem end(s) will be sunken down into the retainer and you can see that from the top. There are good photos of this condition somewhere around this forum. What you do is up to you and I can certainly understand making the decision to replace the retainers proactively. But, I believe it is incorrect to say that you can't adequately inspect without pulling everything apart.
rjtrout2000
Apr 11, 2018 01:04 PM
GetRektd
Jun 14, 2016 06:21 PM
turbolovah
Dec 9, 2013 01:00 AM
Donb
May 20, 2010 03:14 AM
RobTheGob
Mar 25, 2010 08:45 AM
