How do I remove the defroster button panel?
Old Jun 20, 2005 | 07:46 AM
ggarriso's Avatar
Default How do I remove the defroster button panel?
I want to replace the button panel with a change holder. But I cant find any screws holding the button panel on and I dont want to break it..
Here is a link to a pic of the situation
http://tinypic.com/view.html?pic=650mps
Here is the pic if its not a red X
Old Jun 20, 2005 | 08:53 AM
steven975's Avatar
looks like you might have to drill out some of those plastic "rivets"
Old Jun 20, 2005 | 10:00 AM
ggarriso's Avatar
So there is no clean way to remove the button panel? Do they sell plugs so I can plug up those holes and just leave it as is?
Old Jun 21, 2005 | 06:42 AM
ggarriso's Avatar
One last bump.. anyone??
Old Jun 21, 2005 | 06:53 AM
steven975's Avatar
i drilled out those plastic "rivets" to install a shift boot.
it is 2 panels; if you are careful with the drill, you will not punch through the whole thing; the top part will look normal.
Old Jun 21, 2005 | 08:52 AM
ggarriso's Avatar
Mmm.. sketchy, ill give her a shot. Thank you for the reply steven
Old Jun 21, 2005 | 09:01 AM
elmmx5's Avatar
Went through the same procedure when I "polished" my shifter trim piece. I didn't drill anything though, I just slowly pried the pieces apart until the little plastic rivets just snapped. It really didn't take much to do it, just pry slowly and they'll snap rather easily. Whether this will work the same way on the defroster swith, I have no idea.
Old Jun 21, 2005 | 09:08 AM
ggarriso's Avatar
When you say snap do you mean break or snap apart gracefully and can snap back together?
Old Jun 21, 2005 | 09:24 AM
elmmx5's Avatar
No... when mine snapped apart, they broke. It broke the top of the rivets off into little plastic rings that looked like washers leaving the posts behind. I thought about dabbing some epoxy on the posts after I was done so it would be every bit as good as new, but then decided not to since there were already quite a few screws holding everything tight there already and it'd make it easier if I ever wanted to pull it apart again.
Old Jun 21, 2005 | 10:19 AM
ggarriso's Avatar
Interesting.. I am giving serious consideration to just buying two placeholders for those buttons and being done with it all. Thanks for the info
Nicroman
Jul 24, 2014 10:35 AM
adelgigs
Aug 27, 2011 05:46 AM
crdcz03
Apr 14, 2009 07:31 AM
foxer10
May 5, 2006 12:02 PM
ggarriso
Jun 13, 2005 03:49 PM
