How soon can I switch to GM Synchromesh?
Old Sep 8, 2002 | 04:48 PM
Dr. T's Avatar
Default How soon can I switch to GM Synchromesh?
My S2000 has just over 1000 miles on it. After reading all the positive feedback on GM Synchromesh I want to change to it right away. Is there any reason to leave the factory fluid in the tranny any longer? Any breakin period?
Thanks
Old Sep 8, 2002 | 04:58 PM
twohoos's Avatar
Nope, no "break-in" oil in the transmission. Go for the GM stuff!
Old Sep 8, 2002 | 08:45 PM
flytojungho's Avatar
how do you change the fluid? sorry, never changed transmission fluid..
Old Sep 11, 2002 | 01:37 PM
JimmyB's Avatar
Not hard. go to Honda and buy the 2 crush washers, get it up on jack stands remebering to keep it level. Make sure you get a hand pump. Drain out the old fluid and add about 1.5qts of the sycromesh. Keep filling until it over flows. Put on the new crush washers remembering not to tighen thr bolts so tight that you split the washers. Or just take the car, the washers and the 2qts if Syncromesh to you local lube shop and let them do it. They will probalbly charge you around $30.00. The Scncromesh will cost about $10.00 per qt and the washers are around $.18 each. Good Luck!
Frez2k
Sep 7, 2010 10:17 PM
Blue_S2
May 18, 2006 12:05 PM
henesse
Mar 7, 2006 12:56 PM
demitri
Sep 5, 2005 08:37 PM
p0pe
Jun 15, 2005 08:42 PM
