How to unlock s2k when battery is dead?
The coldest temperature in Slovenia today is 30 degrees and the warmest is 55.
http://classic.wunderground.com/cgi-...Select=WEATHER
Anyone still buying that the locks are frozen?
Anyone but me and a couple of others now thinking that this thread is fishing for ways to break in to an S??
Somebody just help this poor guy already. Have you tried getting inside through the trunk? You can take the trim pieces off and then you can make like a piece of metal or wood to pull the hood release from back there.
i had to help a freind get into his Camaro a few times, the window is similar to the S(no fram around the glass) and what we did was to simply pull the glass away from the seal just enough for me t oget my arm into the car and reach down to open it. Looking at the vid, the keyhole locks look like they have been disconnected or have somehow broken loose(which i doubt as my 20 year old Accord has never happened nor My01 S2000).. thats my best suggestion, your key is moving fully so if the lock cylinder was properly connected it would open if things where connected properly
if the lock mechanism is not properly connected the locksmith will be of no use as all he is going to do is jimmy the door to do what the key does, only from in back of the lock cylinder, not the front like the key does
Originally Posted by trAP2' timestamp='1330579161' post='21465005
If its really causing you this much trouble post something that shows proof of ownership and we will let you know what to do...................
is this good enough?
