How to unlock s2k when battery is dead?
Old Feb 24, 2012 | 12:58 PM
  #61
Akiba17's Avatar
It was presumptuous of me to assume a rough median and set it as absolute. My apologies. Here is an apologetic muffin.
Old Feb 24, 2012 | 01:21 PM
  #62
Drkphnx's Avatar
Thanks :brohoof:
Old Feb 24, 2012 | 03:46 PM
  #63
SheDrivesIt's Avatar
Originally Posted by hand banana
Originally Posted by SheDrivesIt' timestamp='1329847524' post='21435853
Give 'em both negative reps, Gigdy! Oh, damn.......
a negative rep for voicing an opinion on an open forum.......
Now was I even speaking to you? Speaking of you, yes. To you, no.
It's a joke, dude. It was for Gigdy's amusement.
Old Feb 24, 2012 | 05:17 PM
  #64
TVPincDoc's Avatar
Perhaps it would be easier if you actually pay for it first? You'll get a little metal thing called a "key" that should open that pesky door right up.
Old Feb 24, 2012 | 07:28 PM
  #65
thielepr's Avatar
well I read all these three pages and the guy haven't open the car yet. It could be, it would be a very strange concidence that both door have the inside lock broke due to the cold temperatures. It's a plastic piece that is attach behind the lock inside the car. It happen to me on the driver door. No matter what I did the door didn't open. The fob and keys were working but the inside lock didn't move. I did open the passenger door and then open open the door from inside. Order the the plastic piece and viola!
But two doors at the same time??? I doubt it
Old Feb 25, 2012 | 07:40 AM
  #66
AngryTurtle's Avatar
Originally Posted by hand banana' timestamp='1329849520' post='21435977
[quote name='SheDrivesIt' timestamp='1329847524' post='21435853']
[/quote]
I found the humor.
Old Feb 29, 2012 | 12:26 PM
  #67
ninchh09's Avatar
Originally Posted by stezie
I did the following to an old car that Deadlocked itself and had a flat battery and would need the central locking to unlock again..
As I could not enter the passanger compartment to pop the bonnet/hood, and put on jump leads, i was able to open the boot/trunk lock with the key. I attached the negitive lead to a solid earth point(boot lid striker) , i then popped out the trunk light and removed the bulb. I then attached the positive lead to the positive wire and the central locking was able to draw enough power to open the locks to the passenger compartment...
Maybe this might help you unlock your car if the key does not work in the door...
Note: do not turn on the ignition on anything else withthe battery pack like this.. as soon as you open the door, jump start the usual way.
i tried connecting the battery charger to trunk light..i left it 1 day charging and try to unlock after 1 day and i still cant unlock it..probably the wire from trunk light is too tiny to be able to charge battery...
i don't want to brake into my car and causing damage on it... I will try to open the hood somehow to reach battery and replace it. Today i managed to put my hand into front fender and reach the lock..i can see the lock but i don't know how to open it..
Does anybody have technical picture of lock of the front hood or maybe someone already tried to do this so i can get a picture how to open it by hand?
Thx, br
Old Feb 29, 2012 | 12:56 PM
  #68
FearlessFife's Avatar
Old Feb 29, 2012 | 12:57 PM
  #69
ninchh09's Avatar
Originally Posted by FearlessFife
Do you have some problems or what?
Old Feb 29, 2012 | 12:58 PM
  #70
NH_s2k_Guy's Avatar
The coldest temperature in Slovenia today is 30 degrees and the warmest is 55.
http://classic.wunderground.com/cgi-...Select=WEATHER
Anyone still buying that the locks are frozen?
Anyone but me and a couple of others now thinking that this thread is fishing for ways to break in to an S??
