i need advice for the track..
Old Jul 19, 2001 | 09:33 AM
BigRedDog's Avatar
i'm pissed...i made it to the track a lil after 5...and BLAM... a long ass line ... i never made it in..2nd week in a row it sold out.. i think next Wed i'mma leave work early... i might feel under the weather that day *cough* ..
Violation: As for info on wed nite drags...you gotta get there at 4ish..cuz since a lot of people are dragging their bikes now.. the space is limited cuz at 10pm sharp they end the races..even if its not finished.. If your down to go let me know.. we could meet up in Vallejo and roll there together..
Elevation.. u wouldn't recommend dumping it? so do i just let it slightly grab before i punch it? what RPM would you suggest? I appreciate the advice.. the more input.. the better experience i'll have..
Old Jul 19, 2001 | 10:05 AM
Elevation S2's Avatar
Elevation.. u wouldn't recommend dumping it? so do i just let it slightly grab before i punch it? what RPM would you suggest? I appreciate the advice.. the more input.. the better experience i'll have.. [/B][/QUOTE]
Well I've done some street racing out here and it seemed that when I launch at 7 grand that the S2 tends to bog some. So here's what I do step by step
Roll-in the the stage position
Pull up the E brake
Throw it into 1st
Rev that F20 to 8 g's
Holding the E brake button so it's ready to be dropped!
As soon as the third yellow goes off on the tree release the clutch and when you get some traction drop the E brake and GAS IT!
Shift smoothly at 9 grand and by the end of the 1/4 you should be in 4th at about 5000 rpm's or so.
It all happens so fast, but it's exciting. Little by little you'll get the hang of it.
By the way what's the elevation there and how hot is it?
Oh yeah I beat a Stock Acura NSX by 2 one hundreths of a sec. whooo hooooo. It was Spa Yellow vs. Spa Yellow Pearl
Old Jul 19, 2001 | 11:32 AM
Jay Li's Avatar
BigRed, do NOT slip the clutch. This will smoke your clutch, and is not recommended.
Old Jul 19, 2001 | 12:50 PM
BigRedDog's Avatar
what do you mean by "slip"?
Old Jul 19, 2001 | 12:54 PM
[QUOTE]Originally posted by Jay Li
[B]BigRed, do NOT slip the clutch.
Old Jul 19, 2001 | 01:17 PM
ace039's Avatar
[QUOTE][i]Well I've done some street racing out here and it seemed that when I launch at 7 grand that the S2 tends to bog some. So here's what I do step by step
Old Jul 19, 2001 | 01:48 PM
Originally posted by ace039
I don't understand, what is the purpose of holding the E-brake until the tires get traction? I was taught you sidestep around 7rpm, feather the gas until the tires stick and THEN gas it. Can you explain what holding up the e-brake does , thanks
The only reason I hold the E brake is sometimes their is a downgrade "all tracks arn't perfect" and it's kind of embarassing if you roll-off the staged position. It's something my racing buddies and I have done for years and have gotten used too.
Old Jul 19, 2001 | 01:56 PM
BigRedDog's Avatar
i found that at times i roll off stage (in my old Civic), but what i was told is that since it is completely flat.. you must come to a COMPLETE stop and you shouldn't roll..i dunno.. but it works for me.. okay.. what is the difference with "side stepping" and "dumping"? thanks...
Old Jul 19, 2001 | 07:15 PM
ace039's Avatar
I have came to the understanding that "sidstepping" is when you put the egde of your shoe on the edge of the clutch and just slip your foot of the side. ( i had to cut of the lower,left rubber stub off to do this easier) And dumping is when you just lift your foot off the clutch as fast as you can. Not as fast as sidestepping but good if you like some rubber on your tires.
trebor8915
Mar 22, 2011 08:21 AM
StarvinMarvin
Mar 8, 2007 11:50 AM
ShocK
Oct 15, 2006 01:02 AM
HiRpmVTEC
Aug 22, 2006 09:02 AM
Jay Li
Jul 13, 2001 11:26 AM
