I need some help
Old May 21, 2006 | 11:53 PM
beartyper's Avatar
Default I need some help
Hi all first post but i need a bit of advice.
I currently have a Civic Type R but am looking to switch to a S2000, i have found one but it is an import.
Its done 51k miles and in very good condiditon inside and out apart from the front right wing seems to be a slightly different shade to the rest of the car!
I have driven it and it drives nice and everything inside and outside the car looks and works lovely but i was just concerned incase it had been involved in a major accident in Japan and then brang over here...is there anything i can do to check if that is the case?
Any advice will be greatly appreciated.
Thanks
Tony
Old May 22, 2006 | 12:04 AM
RACER's Avatar
Eyeball the paint. Check to see if the texture of the paint is consistent on ALL the body panels. Check for oil leaks under the hood. Even inspect the under carrage for possible parts that have been replaced or cosmetic damage. Have a compression test done prior to writing any checks.
Old May 22, 2006 | 03:12 AM
beartyper's Avatar
Im getting a RAC 166 Point check on the car. hopefully should this should be ok
Old May 22, 2006 | 03:14 AM
DiamondDave2005's Avatar
And try asking this question in the UK forum, where they can give you the specifics for UK imports.
Itchy Dick
Car Talk - Non S2000
May 22, 2011 10:02 PM
oo7ml
Apr 24, 2008 10:29 AM
beartyper
May 25, 2006 08:57 AM
PathNull
Mar 26, 2004 08:42 PM
