im going rotary
Old May 11, 2010 | 07:28 AM
  #51
deathsled's Avatar
Originally Posted by 34witt,May 11 2010, 07:37 AM
You said your in Germany, what part? I will be there in July. I would like to see this.
He said he is just stationed in Germany but a friend will be doing the work, I assume back in the US.
Old May 11, 2010 | 07:33 AM
  #52
HonCBRf2's Avatar
Originally Posted by seoulbro,May 10 2010, 08:24 PM
Mazda should have given up on the rotary engine years ago. I don't care how light it is. The motor has no torque and any boosted mods can blow up the engine.(without proper tuning and low boost) If that's what you want to do, do what makes you happy. For me, I think it's a complete waste of $.
I would put money on one of those old Mazda rotary Cosmos that they run at ALCO over your best modded S2000 motor...like the s2000 motor has any torque?
Old May 11, 2010 | 07:34 AM
  #53
TougeS2k's Avatar
do you have a budget? just wondering if you have a general idea of how much this unique swap will cost?
Old May 11, 2010 | 08:48 AM
  #54
xyster's Avatar
The LS1 is pretty much a stand alone ECU it only needs like 10 wires hooked up to run on its own. As far as the speedo and tach you can run the tach wire from the new motor to the cluster but it depends on what kind of signal it is the LS1 has a 4 cyl. low volt output from the factory so it reads just like a 4 cyl., the speed would come from the tranny speed sensor and go into the cluster as well but it would most likley need to run through a speedo healer to get the signal correct or your speedo will read wrong. I am not sure where these signals come from on the rotory but on the LS1 they come off the ECU in most cases. The S2000 ECU is pretty muched used to run the motor all the other stuff comes from the fuse boxes.
Old May 11, 2010 | 08:53 AM
  #55
xyster's Avatar
im not sure about the ABS since im not running it in my car but I think it just runs off a speed signal and the fuse box. I know that the speed wire the is in the S2000 is Blue/White (pretty sure) runs from the connector under the dash where the factory engine harness would plug in throught the ECU and then up to the dash on the way to the cluster it splits like three times one to the EPS one to the ABS and the other to the cluster. Getting the EPS to work was my biggest issue it needs a tach signal and a speed signal to operate correctly.
Old May 11, 2010 | 10:01 AM
  #56
termigni's Avatar
but why?
Old May 11, 2010 | 10:41 AM
  #57
unclefester's Avatar
Why not?
That's the point I think - will be interesting to see how it comes along.
Old May 11, 2010 | 10:42 AM
  #58
My R2's Avatar
GO FOR IT!!!
BRAP BRAP BABY!!!
In for pics and videos w/sound!!!
Old May 11, 2010 | 11:05 AM
  #59
hirev's Avatar
if this is real and i doubt it, it is nuts, silly, and makes no sense at all, but the guy seems to wan to do it cause he can, that's enough reason for me....
Old May 11, 2010 | 12:06 PM
  #60
1point3_to_2point2's Avatar
i dont know which 13b you are using but to the guy a couple posts ahead of me the rx8 motor was much lighter than s2000 motor
its not all made of iron
