Intake Help
Old Jun 28, 2005 | 10:35 AM
  #21
steven975's Avatar
Originally Posted by jwa4378,Jun 28 2005, 10:21 AM
I am not quite as well versed as some of you, but the RAM style intake exists for a reason, and claims some HP gains....granted not as much as a CAI, but they are still there. Most intake gains only take place with an exhaust / header modification as well. You can only take in as much air as you can get through the exhaust. I thought the premise behind the RAM induction was it crammed MORE air, because it has a wider tubing with less bends and has a higher flowing filter. I under stand that you can get more air in if it is denser (colder), but if you just have a bigger opening, it should allow the engine to suck more air in (think of breathing througha longer / thinner straw then breathing through a shorter, straighter, wider straw. The actual temp of the air, I thought, didnt have anything to do with it, other than the fact that colder air is denser. If you can get more air in, via another route (RAM air), the temp should not much matter.
I may be completely off base, as I am not an engine tech kinda guy, but it makes sense.
John
the temp matters a lot.
the cooler the air, the more oxygen it contains per liter. at one atmosphere, the same number of liters enter an engine no matter what temp.
the more oxygen, the more hydrocarbons burn, meaning more power.
the intake and exhaust are not dependent on each other as the cylinders are filled by vacuum, but expelled by positive pressure. also, the hot air of the exhaust contains fewer molecules per liter, but the same number of molecules leave. Thus "more" air (in liters) leaves an engine than enters it.
Old Jun 28, 2005 | 11:04 AM
  #22
jay3737's Avatar
i have the PRM - it's nice and loud, easy to install (no bumper removal, and cleaning the filter is a snap).
i can email a sound clip to you if you wish -- if interested drop me an email at jeremycriswell@yahoo.com
-jeremy
Old Jun 28, 2005 | 12:11 PM
  #23
Revin9K's Avatar
besides that hp dyno test that TOV did a couple years ago...has anyone else dynoed their AEM v2? the gain should be around 8-10 hp according to that TOV article.
i have the v2, its a great choice for a good price. install is a pain though!
Old Jun 28, 2005 | 01:27 PM
  #24
Nhan's Avatar
aem v2
Old Jun 28, 2005 | 02:05 PM
  #25
Tyler N's Avatar
K&N FIPK Gen 2
Old Jun 28, 2005 | 04:16 PM
  #26
jwa4378's Avatar
Thanks for the input...all I really know about this is what I learned in High School physics. i thought that the exhaust was expelled because it expands when combusted (hence the pistons moving up and down). If you move hot air out the exhaust, it will be at a higher pressure than cooler air, thus creating back pressure. You can only get rid of as much air as the header will allow. When cooler air from a CAI is put into the cylinder (it is "more" hydrocardons and etc. like you said above) and it expands, there is more air to expand, thuse creating more pressure on the exhaust system. This is why most CAI companies usually state that max gains will only be recognized with a high-flow exhaust system.
I was once told that all an engine really does is "move air." This pretty much rings true. The more air you can move through the engine, the more HP you will attain (more combustion = more pressure for the pistons = more HP). The CAI is truely limited by the header and exhaust. If you change those out as well, the HP gain will be even more than if you changed exhaust / header without a CAI.
I was not sure about the short ram air intake...that is what I meant be RAM air not a cowl or hood vent. I thought those were called RAM air because it was a dedicated scoop for the short ram intake.
The CAI does put cooler denser air into the engine, albeit LESS (volume wise) than a short ram system. The short ram system (i thought) put MORE air in (volume wise) that is LESS dense. Either way, you get "more" air into the system. The short RAM is able to move more air, because there is usually at least 2 bends less (bends slow air flow).
So....the way I understand it, the short RAM air intake moves more air volume wise, where the CAI moves less air than the short ram (but more than stock) but move denser air.
Apparently the CAI is better because it reports higher gains, so the denser air contains more hydrocarbons (and whatever else) than the comparatively less dense (but more volume) hot air.
One of my family friends told me all this...he owns a local car repair shop and is a Certified mechanic. But.....he could be wrong. I am just relaying second-hand knowledge. I REALLY enjoy learning about this kinda stuff, so if I am wrong, please correct me and provide an explanation, so I know WHY I am wrong and why the above theories does not apply.
Thanks
John
Old Jun 28, 2005 | 04:33 PM
  #27
jasonw's Avatar
Originally Posted by jwa4378,Jun 28 2005, 05:16 PM
1. This is why most CAI companies usually state that max gains will only be recognized with a high-flow exhaust system.
2. The CAI does put cooler denser air into the engine, albeit LESS (volume wise) than a short ram system. The short ram system (i thought) put MORE air in (volume wise) that is LESS dense.
1. Has the thought occurred to you that they might be trying to sell you an exhaust system? It also varies depending on the quality of the original parts. Quality of original S2000 parts > Quality of original Civic parts... Result: less room for improvement.
2. You have any evidence of that? You are assuming the intake piping is a smaller diameter than it should be...
Old Jun 28, 2005 | 04:44 PM
  #28
S Curve S's Avatar
Originally Posted by Tyler N,Jun 28 2005, 03:05 PM
K&N FIPK Gen 2
Easy Install
Great Sound
No Heat Soak
No Hydrolock
Dyno gains of 9.4 by K & N on AP2, with similar gains proven by member dyno results.
Old Jul 1, 2005 | 11:48 AM
  #29
s2kmiami's Avatar
Banned
dude i'll sell you my v2 make me a decent offer and its yours a month and a half old I got the Arc instead for me i like it better.
STRONGERTHANALL
Aug 19, 2005 10:50 AM
scotchtape
Nov 25, 2004 12:05 AM
S2KNJ
Nov 24, 2004 08:50 PM
owenxguo
Jun 7, 2004 01:08 PM
duck69
Mar 15, 2004 07:23 AM
