ITB question
Originally Posted by Fyrestrike,Dec 11 2006, 12:48 PM
Curious, why did you need larger injectors and an Adj. FPR?
The FPR is to tune the larger injectors with the stand alone ECU I would think.
Originally Posted by wildcardtrd,Dec 11 2006, 04:03 PM
Since the increased airflow from the ITB's requires alot more fuel as well, ITB's force the injectors past 80% duty cycle. The stock fuel pressure regulator is mounted to the stock fuel rail, which can't be used on ITB's. You need to set the fuel pressure to a psi that puts your new injectors into a safe duty cycle.
I think you could get away without the larger injectors, maybe just an increase in fuel pressure
last time I checked wildcardtrd wasn't putting out more power than a stock SC kit, and you can run those on stock injectors. No offense
You could run ITB's on a larger pump and an adjustable FPR, but the stock injectors also physically don't fit in any ITB kit I know of. The height of the injectors is too short, and the o-rings are nowhere near the right size. You could find o-rings to fit, and fabricate a bracket to get the stock injectors to work, but now you're just getting silly. It's cheaper and more reliable to just get new injectors.
Very nice setup you have. By next spring I will have Hayward 50 mm ITB's with my turbo setup. Unfortunately, I suspect that the plenum will kill a lot of that wonderful sound.
Pakisho
Nov 23, 2003 02:21 AM
