Jack points; jackstands
Originally Posted by 124Spider,Sep 10 2004, 09:20 AM
... I am a bit squeamish about driving a car without oil, even for a few seconds.
Off the topic: does your user ID refer to the Fiat 124? My first car, and my last convertible before the S2k, was the 124's less expensive sister, the Fiat 850. It was a real piece of junk, but fun to drive as long as the sun was out and you didn't go over 60!
Originally Posted by A4gsr,Sep 10 2004, 07:03 AM
I am too, so do you push it on and off the ramps? Sounds like too much for these 54 year old bones.
Anyway, I use jackstands, so I don't have to deal with running the car without any oil in it. Pushing a little car off the ramp is easy; pushing it back on would be a trick. I have installed a Fumoto Valve, so that I don't even have to do that (it appears that I can reach through the engine compartment to open and close the valve.
Originally Posted by RACER,Sep 10 2004, 12:14 PM
This is proper procedure. The four designated jacking points are specified in your owners manual.
Originally Posted by foolio,Sep 10 2004, 12:47 PM
Am I the only one that does this?
Jack up the rear-right point, then place a jack stand in front-right point. You're lifting the entire side of the car (2 wheels).
No ramps necessary.
No ramps necessary.
Originally Posted by 124Spider,Sep 10 2004, 12:57 PM
You are correct that, for changing the oil, jacking up the car from just in front of the real wheel will allow you to put a jackstand under the front side jack point. My original post was in regard to how to put four jackstands in place at once, since there was no place where one could put a jack next to a jackstand.
I actually use the same method to get the car on 4 stands:
1. jack up rear right; place jackstand under front right
2. jack up front center (going under front bumper); place jackstand under front left
3. jack up diff; place jackstands under rear left & rear right
#2 might seem slightly unorthodox jacking up a tilted car, but I've personally had no problems and the tilt is very slight.
hth.
Originally Posted by foolio,Sep 10 2004, 01:10 PM
124Spider,
hth.
hth.
spot on!
