jdm headlight HID color....
Old Apr 11, 2003 | 08:12 PM
kush only's Avatar
Default jdm headlight HID color....
my friends tell me my lights are bright white instead of blue ever since i got jdm's.....is this from the RHD bulb angle or does the blue just fade away after a while?
Old Apr 11, 2003 | 10:06 PM
VeilsideAP1's Avatar
the blue is not our hid, as it is 4300k.... the blue/purple cast is because of the housing..... it wouldn't "fade away"... but our lights do look white straight on... I only see them blue going over bumps, etc.......
Old Apr 12, 2003 | 01:57 AM
ASMspec's Avatar
You use your OEM HID setup in the JDM headlamp assembly. Therefore its the same color. The only difference is the part number and the clear lens. The "blue" your referring to actually fades away in time.
Old Apr 12, 2003 | 01:59 AM
S2Kali408's Avatar
It's the alignment. If you can get the lights to go back to factory specs it should look as blue. My recommendation is to get a friend who haven't messed with his lights, have him aim the lights at a wall, and level your lights the same as him (opposite beam pattern ofcourse). It should work.
Old Apr 12, 2003 | 10:17 AM
kush only's Avatar
[QUOTE]Originally posted by JDMs2000
[B]You use your OEM HID setup in the JDM headlamp assembly. Therefore its the same color. The only difference is the part number and the clear lens.
trustafox
Jan 8, 2012 01:06 PM
Frisky
Aug 13, 2006 07:28 PM
iheartmys2k
Dec 22, 2005 02:11 PM
SuzukaBilly
Apr 21, 2004 06:21 PM
jugger23
Dec 17, 2001 01:15 PM
