Krank Vents Review:
Old Aug 25, 2006 | 08:47 AM
  #21
rugsr's Avatar
IVE EVEN HEARD OF GETTING SOME OF THEM FROM FISH STORES, I GUESS THEY YSE THEM IN THE FILTERS...TRUE?
Old Aug 25, 2006 | 08:56 AM
  #22
kane.s2k's Avatar
The krank vents use 2 units. Your PCV valve you got from comptech is just one unit. They do not do the same thing.
Old Aug 25, 2006 | 10:09 AM
  #23
afwfjustin's Avatar
I will be ordering one in the coming months
Old Aug 25, 2006 | 10:12 AM
  #24
kane.s2k's Avatar
Originally Posted by MGRMLN,Aug 25 2006, 06:33 AM
So is this Krank vent good to have on a stock NA 2006 motor as well?
It is a universal application.
We've seen slight HP gains all across the board on N/A cars.
Old Aug 25, 2006 | 10:14 AM
  #25
kane.s2k's Avatar
Originally Posted by floridawriter,Aug 25 2006, 08:49 AM
What happens if you use the vents on an "02?
Same thing for any car really. If you use the system as designed with both units it's a universal application.
Old Aug 25, 2006 | 10:54 AM
  #26
Amer's Avatar
Can anybody install this unit or do you recommend a shop?
Old Aug 25, 2006 | 11:01 AM
  #27
kane.s2k's Avatar
It takes about 2 seconds to install it. If you get stuck with the directions that are printed in the instructions manual, this might help:
http://forums.s2000turbo.com/viewtopic.php?t=368
Order it here:
http://automotivespeed.com/product_i...products_id=49
Old Aug 25, 2006 | 11:02 AM
  #28
bigpurp's Avatar
Anyone can do this. All u need is an exacto knife, a screwdriver and 15 mins of free time.
Old Aug 25, 2006 | 12:35 PM
  #29
Empedocles99's Avatar
So, people are claiming reduction in oil consumption. I assume this is because there is less oil blow-by going around the pistons in to the crankcase. Is this vent going to reducte the cylinder lubrication because of this?
Old Aug 25, 2006 | 12:44 PM
  #30
kane.s2k's Avatar
yes, it can be assumed that these cause less blow-by. This wouldn't affect cylinder lubrication since that is done by oil being splashed/squirted up to the walls and piston. There are holes all around the piston to feed the oil ring. This system just allows the rings to seal up and do their job better.
