Mysterious Dash button marking
Old Feb 8, 2009 | 10:44 AM
  #21
RedDawnFX's Avatar
Well since this thread is brought up for the dead. Topic change.
What are the mysteries of the s2k? Part of the fun of owning the s2k is finding the mysteries you had no clue about, such as the secret compartment.
Post the random things you have found on the s2k.
Just yesterday I found out that pressing the "Ch" button near the volume control on the left of the steering wheel changes to the next track on a cd.
Old Feb 8, 2009 | 10:59 AM
  #22
CKit's Avatar
Today I found that the skinny pedal on the right makes the car go "Vrooom."
(You know, there is a book that answers many of those "so-called mysteries.")
And it's even available for free from Hondalink.
Old Feb 8, 2009 | 11:48 AM
  #23
negcamber's Avatar
Seriously...I'd rather see someone searching, finding an old thread and then asking a clarifying question than someone starting a new thread asking what the little button on the dash does again. At least I can see the new guy is searching.
And he didn't try to answer the OP's original question...like I've seen some others do in the recent past with ancient threads.
Kaneda215...give it a shot and see what happens. You won't break anything. If memory serves, the dash lights will re-dim if you turn the lights off and then back on.
Old Feb 8, 2009 | 12:01 PM
  #24
mikegarrison's Avatar
I'm pretty sure this is correct. Each and every time you turn the lights on, the dash goes from day mode to night mode. The guy who answered that it stays in day mode until the battery is reset is almost completely wrong.
I say "almost". Here's the deal:
There is a default setting for brightness in two modes, day and night. Day is bright, night is dimmer. The selection is done by whether the lights are on or not.
Pressing plus for about three seconds switches the dash to day mode for as long as the lights stay on. Turn them off and back on again, and the car drops back into night mode.
BUT, each of the two modes is also adjustible. When the car is in the appropriate mode, you can press plus or minus repeatedly to brighten or darken the display. This is memorized.
So when you turn the lights on, if you push the plus button many times (not holding it down) you can adjust the night mode up to the brightness of the day mode. In that case it will stay bright all the time until you readjust it (or reset the ECU). OR, you can just press and hold the plus button until the panel jumps into day mode. This is not memorized, and reverts back to night mode the next time you turn on the lights again.
Old Feb 8, 2009 | 04:36 PM
  #25
Rubn1out4GudLuk's Avatar
When I performed the tasks that I suggested in my earlier post(hold down the + button for several seconds(3 or so) until the tach lights up brightly), It kept the setting in the memory...everytime I turn the lights on...The tach automatically goes to full brightness, which is the setting I set it on by holding the "+" button down for several seconds.
I never said "press" once...I've always said "hold"!!!
Old Jul 28, 2010 | 11:36 PM
  #26
chubbychu's Avatar
Does anyone know what that little dot between the odometer and high beam does? or...maybe nothing?
Old Jul 28, 2010 | 11:41 PM
  #27
chubbychu's Avatar
nevermind search is my friend
https://www.s2ki.com/forums/index.php?showt...&#entry14469647
bartonbeau
Nov 10, 2015 05:34 AM
animeS2K
Jan 17, 2008 03:56 AM
emrillive
Nov 22, 2003 05:28 PM
ToyBoy
Sep 15, 2002 08:58 PM
KenS2K
Jul 11, 2001 12:30 PM
