IN NEED OF CLUTCH HELP!
Old Jan 2, 2005 | 06:31 PM
f20c1 01s2k's Avatar
Default IN NEED OF CLUTCH HELP!
my stock clutch is slipping. so i need to change it soon but i dont know which BRAND CLUTCH i should get. my choices were either "STOCK", "ACT", or "EDIXE".
i dont really need a high performance one because im not going TURBO or SUPERCHARGE for a while. Can you guys help me pick out what you think is BEST and what STAGE i should get!? thanks.
Old Jan 2, 2005 | 06:47 PM
xviper's Avatar
You are asking about product preferences and recommendations. UTH is for "How To's" on installation, specs, problems, etc.
Moving to S2000 Talk as per:
https://www.s2ki.com/forums/index.php?showtopic=247214
ps. My response to your question is to look into either the OEM or ACT street disc. The ACT is basically a "reworked" OEM disc anyway. Get whichever one is the right price for you and is easiest to obtain. I've heard that the Exedy (sp?) can be a bit "grabby". You should also consider getting the ACT HD pressure plate. This may help you to extend the life of your clutch a wee bit. It will also give you a slightly "heavier" clutch feel.
Old Jan 3, 2005 | 02:59 PM
hey thanks alot xviper. ill probably go with the OEM then. thanks.
Old Jan 3, 2005 | 04:37 PM
NFRs2000NYC's Avatar
SPEC is really good.....and priced reasonably as well.
Old Jan 3, 2005 | 06:53 PM
Krovvy's Avatar
I think Xviper knows more about this car than anyone one the planet. one of his links solved a problem I had that three tecs at the local dealer had no idea about.
I went with ACT i had to get used to the stiffness.
yaboynick415
Oct 22, 2011 01:05 PM
Silvia_Drift
Jun 14, 2011 10:09 AM
MrChoi
May 7, 2009 01:18 AM
AndyFloyd
Apr 27, 2009 07:59 AM
s2kntx
Nov 3, 2006 05:56 PM
