Need Help bought an S2K with no Ignition !
Old Jun 2, 2009 | 05:57 PM
07BBCR's Avatar
Default Need Help bought an S2K with no Ignition !
Hello im new here, i bought an 2007 Berlina Black S2000 and its missing some parts due to theft recovery. I replaced already almost all the parts except for the slashed soft top. My problem is when i bought the car the ignition was completly missing and no keys came with the car. I installed door locks, complete steering column with the complete ignition, ecu and even door lock module(behind the dash) and i got a set of keys. The ignition/ecu/keys all came from an 08 parts car. For some reason the car dosnt start Any suggestions ?
I'm planing on towing it to honda dealership at the end of the week if i dont figure it out, i just really dont want to be stuck with a huge bill at the dealership.
Any suggestions would help thank you in advance
Old Jun 2, 2009 | 06:55 PM
downloader's Avatar
you have the immoblizer system. The ecu must be programmed with your keys. I think its dealer only, or someone that has the honda HDS. You will need the ecu immoblizer code with changes every day. Good luck
Old Jun 2, 2009 | 07:36 PM
Suzuka_Joe's Avatar
they should if they worked in the last car
Old Jun 15, 2009 | 05:14 PM
07BBCR's Avatar
yeah the ecu and keys and igniton are out the same car so everything should start, i took it right now to a dealership and they are saying that the ecu is not working with their computers. i believe it is wiring problem not the ecu as they tried two of them the original and the one i replaced from parts car, which i know for a fact worked on the parts car.
Old Jun 15, 2009 | 09:11 PM
chris_barry's Avatar
Get your new keys programmed into the original ECU that came with your car.
There are slight differences between ECU wiring for different markets. I found the US ECU's wont work in an AUS market car.
killasystems
Feb 1, 2008 05:56 AM
phinancer
Jul 30, 2007 10:57 AM
freshs2k
May 14, 2007 08:00 AM
jimbo69ny
Jul 10, 2003 08:53 PM
