need some advise on which tanabe exhaust to get?
im stuck between tanabe Concept G or the tanabe Medalion Touring both look good, both are quiet not loud.. whick one should i get?? or is there other quiet exhaust out there.. i have an 2004 with only an intake .. thanks guys
I have the concept G and I like it. The touring may be a bit quieter than the G. There is a bit of resonance (drone) when on the throttle between 3-4k rpm, but it's fairly sedate when cruising. When you're into vtec the exhaust is pretty noticable. The concept G looks good IMO, and drops about 20 lbs off the stock exhaust. I'm not sure if it makes any gains...if it does it's in the higher rpm range as it's a straight through exhaust rather than the indirect rear stock mufflers.
I think the SMH and Medallion touring are comparable. I like the medallion touring better as it seems to have smaller mufflers - less attention grabbing IMHO. But, I am stuck between this one and Fujitsubo....They both seem pretty comparable!
