New car dip stick check
Old Sep 8, 2006 | 02:18 PM
Chipster's Avatar
Thumbs up New car dip stick check
I know it is important to keep an eye on the oil level in the powerplant of the S2000 as you break it in. I was curious to know what you long term owners found as your car transitioned from "new" to "not so new"? I have read here that some cars consume more oil than others, but is there a "normal" in terms of oil consumption? I imagine that "right foot enthusiasm" plays a major role in this issue. What was your experience, and was there a point in the break-in that your car quit showing oil loss? Thanks
Old Sep 8, 2006 | 04:25 PM
SheDrivesIt's Avatar
I used about a half quart in the first 1500 miles or so. Nothing afterwards up till I changed it at 5K. No oil useage since. I run 5K changes and switched to synthetic at 10K miles.
Old Sep 8, 2006 | 04:30 PM
dryfly's Avatar
I didn't need to add any prior to the first change at 3500 miles. I hear the AP-1 engines go through more oil.
Old Sep 8, 2006 | 04:47 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
+/- one quart,every 1500 miles,is normal,if you drive it like it should.
Old Sep 8, 2006 | 04:49 PM
willinathen's Avatar
I've checked mine a couple of times, my06. at 1000 and 1800 miles, no usage yet.
right at the full mark
Willinathen
Old Sep 8, 2006 | 06:10 PM
Yflyer's Avatar
My '06 used less than 1/4 quart before the first oil change at 4500 mile. No oil usage since, and plenty of Vtec.
Old Sep 8, 2006 | 08:39 PM
steven975's Avatar
The AP2s are known for using less oil.
Honda refined the method in making the AP2 motor. When a head is bolted to a block, it deforms the block slightly, making the cylinders warp a little. Oil can escape by the rings as a result.
On the AP2, honda torques a dummy head to the block and then hones the cylinders. The result is that the cylinders are a more perfect circle when there is actually a head torqued to the car. As a result, less oil gets by the rings!
Jrse7en
Jul 26, 2011 06:04 AM
SpudRacer
Aug 16, 2008 08:08 AM
JJARVIS
Apr 2, 2007 08:14 AM
toroy82
Feb 25, 2007 07:57 AM
diGital.James
Feb 6, 2003 10:17 PM
