Power Mirrors Not Working
Old Feb 18, 2009 | 07:44 AM
Artric's Avatar
Thumbs down Power Mirrors Not Working
Just bought my 04, but more about that later.
The mirrors don't seem to adjust. I've flipped all of the switches. Is there a trick?
Old Feb 18, 2009 | 08:12 AM
SheDrivesIt's Avatar
Well, you have to select left or right since the center position on the selector switch turns them both off. Other than that, may be a blown fuse or someone had the door panel off and forgot to reconnect the mirror switch assembly.
Old Feb 18, 2009 | 08:32 AM
J5sense's Avatar
could be a bad switch too. try moving it in all directions really fast
Old Feb 18, 2009 | 04:31 PM
a_zepeda926's Avatar
see if your cig lighter works.. i had an issue with an accessory relay and it affected my stereo/acc jack/mirrors.
Old Feb 18, 2009 | 04:40 PM
BlackBearTX's Avatar
You flipped all of the switches? I can't find a pic and don't feel like going out to my garage, but I am pretty sure it is on the driver side door or near it? Select right or left and adjust from there?
Old Feb 18, 2009 | 05:50 PM
^i hope thats not the issue.. haha
Old Feb 20, 2009 | 03:22 PM
Artric's Avatar
Hey, forgot I posted this.
It's weird, they weren't working, and then they were... not sure what's going on there. I haven't tested the accessory connection yet. If they continue to act up, I'll have to troubleshoot further.
At least I was able to adjust them properly for me, so I should be good safety-wise.
Old Feb 20, 2009 | 03:40 PM
JeremyStone's Avatar
I sometimes have a problem where the ABS light comes on, the HVAC controls won't work or light up, and the mirrors won't adjust all at the same time. Usually happens after startup and then goes away after a couple minutes. Never figured out what it was, but it hasn't happened in a while. You can find a lot of people with the same problem on here, but no definite answers posted.
Old Feb 20, 2009 | 05:01 PM
sounds like the exact issue i had. plug something into your acc jack, like a cell phone charger. see if your cd player goes or, or if any other fuctions are not working.
M-Type
Dec 7, 2012 04:24 AM
chikin tities
Oct 17, 2012 03:26 PM
NavinRJohnson
Oct 21, 2008 05:17 PM
NavinRJohnson
Oct 20, 2008 06:42 PM
Trigun
Nov 28, 2005 05:56 PM
