problem with corner lights
Old Mar 31, 2006 | 06:23 PM
darkfx's Avatar
Default problem with corner lights
After I installed ricks diffusers, when i lock my car via remote.. the side lights and the front diffuser lights dont work.. when i have my turn signal or my hazards on they work.. they also dont work when the headlights are on.. any advice?
Old Mar 31, 2006 | 06:33 PM
S2KinVA's Avatar
Thats how they function. The fender light is for the turn signal and not for running lights.
There are 2 bulbs, 1 for "parking lights" and 1 for turn signals. When you click the remote to lock the car only the bottom "parking lights" should flash.
Old Mar 31, 2006 | 06:36 PM
xviper's Avatar
Do any lights blink when you lock the car?
Old Mar 31, 2006 | 06:40 PM
darkfx's Avatar
the tail lights blink, the sides and front do not.. it only start after the diffuser install, and none of the lights blew.. is there a seperate fuse for this function?
Old Mar 31, 2006 | 06:46 PM
xviper's Avatar
You have 4 "park" lights - 2 in front and 2 in the tail lights. They're all on the same circuit, so if your back ones blink when you lock the car, that means that something is wrong with only the front park lights.
I would suggest that in the process of taking apart your headlights for the diffuser clearing, you didn't plug the park light wiring harnesses back in or you plugged them in wrong or didn't plug them in solid enough. There is also a very slight chance that in the same process, both the park light bulbs took a crap. This has been known to happen.
Old Mar 31, 2006 | 06:56 PM
darkfx's Avatar
I'll check the bottoms.. Maybe when I was looking it gave the illusion that they were lit, but it was the upper lights.
CitadelBlue
Mar 10, 2015 01:17 PM
Joseito92
Feb 15, 2012 02:36 PM
bbss2k
Jan 25, 2012 05:25 AM
tom717
Jul 13, 2004 02:22 PM
NFRs2000NYC
Sep 16, 2003 10:13 AM
