question for some 4.77 owners
Originally Posted by s2000Junky,Nov 1 2007, 02:08 PM
Sorry to hear that, I know the answer. But seems to me that for a quarter mile drag race you want the gear choice that alows the least amount of shifting that will also maximize the power your making to the ground right? Which in your case is 235hp which is fantastic. Pm me and let me know what your list is because i'm very interested
The other factor to maximize your time and speed going through the finish is picking a gear that will get you to peak hp right at the end.
Did you know that the 4.44 get you to a perfect 60mph with one shift and will get you to almost a perfect rpm for maximum pull at the finish line over any other gear available? This is just the shifting reasons not to mention the other points I described about how gearing affects performance.
Higher gears are a band aid for low power, you are not FI power but you are most definetly in the power range to see better results from lower gearing then the maximum band aid available.
The other factor to maximize your time and speed going through the finish is picking a gear that will get you to peak hp right at the end. Did you know that the 4.44 get you to a perfect 60mph with one shift and will get you to almost a perfect rpm for maximum pull at the finish line over any other gear available? This is just the shifting reasons not to mention the other points I described about how gearing affects performance.
Originally Posted by qbmurderer13,Nov 1 2007, 08:14 PM
guys, not that im saying the s2000junky doesnt know his stuff but you shouldnt really make a decision on what one person says.... do the research yourself from different threads. i still fail to see s2000junkys point
if you guys look at this thread https://www.s2ki.com/forums/index.php?showtopic=522272 then you will see that in the 1/4 graph with the ap1 stock vs ap1 geared, that the 4.77's came out on top...
4.77's hit top speed 147mph in 45 seconds
but yet it takes the 4.44's about 68 seconds to reach top speed of 153mph
0-60 the 4.77 loses because you have to shift again but who really cares? who stops racing right at 60, if you were to race 0-65 or 0-70 the 4.77's will win.
4.77's will always reach top speed MUCH earlier than all the other gears, if you have over 240whp then yes a lower gear MIGHT suit you better.
but i see no evidence or logic as to why the 4.77's will actually be a disadvantage after 30.... the 4.77's will be a disadvantage at 90mph and up. those graphs prove the 4.77's pull harder in each gear and stay ahead through the whole 1/4 time and race to top speed.
This was a thread that I was apart of many months ago when it was in its early stages, however there is a second link floating around which is the original and there is some different discussions of whats going on there. Its interesting to hear peoples responses to that thread which sometimes can be just as helpful. There are a few smart people floating around.
I'm sorry you don't see my logic or the points I made. This doesn't mean someone else doesn't have this ability. I don't much care for being invalidated from you after spending so much time offering up my energy into the subject. What are you offering here other then some mixed up formulations of what someone else created. His information is really interesting and definetly a good solid basis at trying to figure this gearing thing out, but even he stated that its not 100% accurate and I myself don't understand the formulas he used to create the simulation, something he learned in school apparently. I offered a formula that anyone can use and understand to find their own answers.
Originally Posted by JLEEzAP2,Nov 1 2007, 05:38 PM
Everything you say pretty much states " 4.44 is the best and nothing else can compare to it." But your pretty wrong. 4.44's won't get you to 60 in one shift. HELL stock gears on an AP2 won't make it to 60 in one shift. Stock AP2 redlines 2nd gear at 57 mph which requires another shift anyway. Also, an Ap2 will need to shift to 5th gear STOCK to get passed the quartermile. 4.77's will require the shift to 5th gear also. So in a quartermile race 4.44's vs 4.77's, can you explain to me why the 4.44 would win?
where did you get your information saying that the 4.77's are useless after first gear and actually are a disadvantage from 30mph....
Originally Posted by JLEEzAP2,Nov 1 2007, 08:27 PM
My post was just a response to this. I haven't read the whole thread, but the guy that posted before you has an 06 AP2(his username). And then he thanked you for helping him choose, but your theory wasn't correct for him. I dont have any experience with the AP1 so
Originally Posted by s2000Junky,Oct 31 2007, 03:46 PM
I currently run the Azenis 615 215/45/16 w/factory wheels
That pretty much kills any credibility for me. That and I have owned 4.44's in the past and use the 4.77 now.
BTW, someone asked for this earlier: http://www.turnzero.com/technical_resource...gear_calculator
Originally Posted by e3opian,Nov 1 2007, 09:55 PM
Man I hope you aren't running 215's in the back...
You'll have to excuse my frustration, i'm getting pretty annoyed with certain people trying to discredit me that don't have a full understanding them selfs. Its pretty stupid. I'm not sure what the motive is.
So tell me how my choice in a 215 tire in the rear discredits me? and After all you have read if you have read anything? So I don't have to repeat myself to many times you can go to this thread and understand what the benifits are and what the thought process was that got me to making that decision before you jump to too many uninformed conclusions ok? I'm doing you a service here. Take advantage of it and maybe learn something if you open to such a concept
https://www.s2ki.com/forums/index.php?showt...&#entry11787360
By the way I don't care what gear your running currently, but what I think is amusing is that you apparently made an error in choice the first time. How does it feel to make a mistake on such an expensive mod? I could have probably helped you before but too late now. learning by trial and error is expensive isn't it? There is a way that you could have figured out exactly what you were getting the first time. Are you a drag racer, street racer, X guy or just like the feeling of more tq multiplication a higher gear set provide?
I agree with GBmurder13, I would think 4.77 would have a advantage until at least 90. The 4.77 should not only launch much faster but would pull even afer that. If 4.44 could catch up after 30 I don't think anyone would have ever even considered this mod. I have taken my car 4.10 to the track, I am purchasing 4.77's at the advice of HTG. He should know that's all he does. My2 cents.
I am a total n00b at this gear stuff. I have started getting into tracking and Auto-x'ing my car a little bit and I think I can see where gears will help me out some. I am considering the 4.56's because of the loss of top speed with the 4.77's. I have gone well over 120 at a few of my track events.
I guess my question is why do you think that a 215 tire alters the gearing? I run 245's at the track... Am I hurting myself???
I think I found the answer to my question buried in one of the posts above.
It is not that s2000Junky think a narrower tire is better just that the better tire he found is only available in a 215 width...
I personally do not think that I would explore his "tire mod" with such a narrow tire. Even if it is stickier then an S02. Snap oversteer is VERY ugly.
Especially since my suspension is setup to run with my wider-than-stock RA-1's.
