Question for those with vented hoods
Old Jun 4, 2004 | 08:41 PM
GTI 20v's Avatar
[QUOTE]Originally posted by Bass
Old Jun 4, 2004 | 10:38 PM
biker1's Avatar
For tuned cars there fairly important in keeping "all" cool while on standard cars they just have the "look good" factor ( if you like that sort of thing )
I have a Top Secret hood and the rain channels are effective even if they do look a bit crude.
Old Jun 5, 2004 | 02:02 AM
NNY S2k's Avatar
[QUOTE]Originally posted by GTI 20v
Old Jun 5, 2004 | 04:39 AM
turbo_pwr's Avatar
Originally posted by jarod
Any of them look like this one?
http://www.ryanpeters.com/zoe/type-r-bassinet.jpg
Minus the baby of course...
Well considering the engine is in the back the vent has to serve some purpose.
Old Jun 5, 2004 | 11:54 AM
frans2k's Avatar
With a supercharger it gets really hot in there, I imagine a vented hood would help to get that hot air out.
Old Jun 5, 2004 | 01:18 PM
xviper's Avatar
Also, if you change to an aftermarket header that does not have the same sort of heat shields that the stock one has, it gets REALLY hot under the hood. A vented hood is almost a must. I have recorded underhood temps getting up to as high as 70*C 5 minutes after shutting down. I can imagine how hot it gets with no heat shields. Temps that hot is not good for the battery or other underhood components that would not normally see those kinds of temps.
Old Jun 5, 2004 | 02:03 PM
HI SPEEDR's Avatar
As far as lower temperatures in the engine bay, why not drill out the dummy vents in the grill. Would that help? I know that when I had my '03 CL Type S, the Icebox induction that I got from CompTec dropped down below right in front of the dummy vents, so I drilled them out with a 1/4" drill bit.
Old Jun 5, 2004 | 07:31 PM
Bass's Avatar
the dummy vents do not lead into the engine bay of the s and will not help unless you cut up the plastic
Old Jun 5, 2004 | 08:20 PM
JL9000's Avatar
I have never understood the point of a vented or CF hood on an S2000.
Good ones save weight, vent heat, and reduce drag at high speeds.
Remember, weight reduction adds up. You're not going to be able to swap one part and get a night and day difference.
blackfx35
Jun 16, 2010 03:48 PM
Bullitt44
Mar 4, 2005 01:13 PM
iCEE
28
Sep 18, 2003 03:55 PM
RevIllusions
Sep 4, 2003 05:36 PM
WongGahming
Aug 3, 2003 02:55 PM
