quick question
Old Jun 23, 2006 | 12:55 PM
jiggarex's Avatar
Default quick question
does anyone know how to reset the cel in the s2k ap2. u press one of the buttons in the tach in a combination or something. and i was wonderering how it is done???????? cause my car makes it go off evey 6k miles or soooo its weird...
Old Jun 23, 2006 | 01:00 PM
ThatllHappen's Avatar
Do you mean the maintance req light?? If it is that, then read in your owners manual on how to reset that.
Now if its the check engine light (cel) that is going off, you need to get the codes checked before you try to reset it.
Old Jun 23, 2006 | 01:07 PM
vtec9's Avatar
no light is 'weird' they come on for a reason. if its the maint req light, the car thinks its time to change the oil. if its the check engine light, you better pull the code before you try to reset it.
Old Jun 23, 2006 | 06:31 PM
gomarlins3's Avatar
If it's a true 'cel' get the code pulled at an auto parts place and come back here and check it either here:
https://www.s2ki.com/forums/index.php?showtopic=378792
or post the 'cel' number here and we can try to help you.
Old Jun 23, 2006 | 09:19 PM
SIIK2NR's Avatar
READ THE OWNERS MANUAL!!! It will tell you how to reset the "Maintenance Required" light.
If you can't distiguish the two...then no need explaining how to reset a true "Check Engine Light"...or "CEL"
cesarortiz
Nov 7, 2011 09:41 AM
Calamari
Sep 15, 2010 03:26 AM
fallcityfisher
Apr 6, 2006 06:54 AM
zzz36
Aug 19, 2005 10:15 AM
Saki GT
Jan 9, 2005 06:34 PM
