Red Learning Key - Help Needed
Old Jan 15, 2001 | 07:06 AM
Sev's Avatar
Sev
You got a small key tag with your car. I believe thats what has your imobellizer info on it.
As far as my understanding goes, all you need is that + your keys and the dealer should be able to re-program them for you. I don't think you need the car to do that. The code is on the little tag ...
This is of course if nothing is wrong with your ECU.
Don't put the red key, it erases memory, i am sure it is from your lude since the s2k didn't have one.
Old Jan 15, 2001 | 07:54 AM
RandyP's Avatar
Since none of your keys work, it is likely that the 'immobilizer receiver unit'(ignition lock) part on the car requires replacement. This is something that sends the ECU a signal from the key. Helms repair manual says that reprogramming is not required to replace this part, unless the ECM was also replaced.
Old Jan 15, 2001 | 08:31 AM
HopkintonMA's Avatar
Service manual says that if it is necessary to rewrite the ECM, the dealer will require the vehicle along with all the keys.
Old Jan 15, 2001 | 08:46 AM
Sondra S2K's Avatar
I had the red key with my '99 Prelude also, but not with the S2000. I suspect you tucked the red key away for safekeeping and forgot about it!
Old Jan 15, 2001 | 08:56 AM
charlie's Avatar
sorry to go off subject here but Tom I see you sold you Prelude, did you get your price?
Old Jan 15, 2001 | 12:04 PM
VisualEchos's Avatar
DO NOT PUT THE RED KEY IN THE IGNITION!!!!!!!! That key did NOT come with your stook, it came with your prelude. Only the dealer should ever put that key in the ignition, and only if they know what they are doing (which apparantly they do not so don't let em touch it!). That key is to reconfigure the Immobilizer circut on your old car, it will freak the new circut.
Andrew
Old Jan 15, 2001 | 02:55 PM
Colin's Avatar
Do Not use the Red Key. It is not for your car and will not help. There are two types of immobilizer systems, the original was in the Acura RL and Prelude and these used the red programing key. This was used to WIPE OUT ALL the codes in the system. The dealer would then plug in their computer and one-by-one "teach" the car the new codes.
The newer type in the Accord, Integra, TL, CL, and S2000 does not need the programing key to reset the computer. The tech plugs in the computer and this "resets" the system and allows the addition of extra keys.
Hope this helps,
Old Jan 15, 2001 | 03:07 PM
redleader's Avatar
The manual talks about the immobilizer keys. I remember it saying something about how having other immobilizer keys near it or other electronic gadgets on the same key chain can screw them up.
abominablehitman
Apr 10, 2006 07:14 PM
jimmij
Apr 25, 2005 05:37 PM
lips2000.5
Aug 1, 2003 01:02 PM
FormerH22a4
Mar 13, 2002 02:41 PM
GTAS2000
Feb 11, 2002 10:40 AM
