Removing the top frame to replace the top?
Old Feb 17, 2012 | 11:00 AM
WarrenW's Avatar
Default Removing the top frame to replace the top?
I'm looking at doing a top replacement again and I'm not looking forward to it. Seems like I saw a post that said it's easier to replace the top by removing the frame then putting the top to the frame. Is this the case? Anyone have a link to that thread or have a PDF on how to do this?
Old Feb 17, 2012 | 01:36 PM
emdzey01's Avatar
You might have misread the posts.
I believe it's easier to replace a top by replacing it with another one that already comes with a frame (most likely a used one).
It's not easier to replace a top by installing it on a removed frame; you're just looking at more work for the same results.
Old Feb 17, 2012 | 04:47 PM
Duke Togo's Avatar
I just redid a top last weekend and we left the frame in place per the instructions. If you are going to do it make sure you read the instructions first, check to see you have the straps and rivets necessary before hand. And remember new tops have new material and it needs to be stretched out. You make have to really pull down hard for the last couple of inches the first few times you put it back up. If you are buying a used top its not going to have that issue.
Old Feb 17, 2012 | 05:25 PM
Brndon's Avatar
Yea, i replaced my with the frame in aswell. Bought my top off ebay from a company called AUTOTOPS its came with a DVD and without the dvd it would have been a nightmare
Talent
Sep 29, 2019 11:35 AM
B0neSt0ck
Jul 1, 2012 11:42 PM
skool u
Apr 23, 2011 11:57 PM
DoubleHelix
May 28, 2010 07:26 AM
S2000driver77
Jan 6, 2005 02:38 PM
