Resetting ECU - Problems
Old Oct 20, 2005 | 12:55 PM
Ogre's Avatar
Default Resetting ECU - Problems
Well at first I tried pulling the "backup" fuse to no avail then left the negative off the battery over night and heres where im suprised.
Reason im resetting the ECU is to get rid of check engine light. Basically around 78000 miles the check engine would flash on startup and then turn off. From reading here thats to indicate a required service interval. So finally around 80k it stays on indicating service time.
Well its on the list to do but money is money and I was trying to clear it off so if anything did happen I would notice from a actual check engine light.
Anyways so this morning I rehook up the batter and before I even turn on the car check engine light is on, just had the key in the start position. Turn it on it goes through its "fuel trim" so I know I reset the ecu.
So do not know what to do at this point.
Old Oct 20, 2005 | 02:00 PM
thetz99's Avatar
You are confusing the Check Engine Light with the Maintanance Required Light.
You don't reset the ECU for the Maintanance Required Light reset.
To reset the MAINTENANCE REQUIRED light (As indicated by the light that says, "MAINT REQU'D"):
- Have key inserted in ignition but in the OFF or LOCKED position.
- Push and hold the trip reset button on the right bottom corner of your gauge clutster.
- Turn key to full ON position and continue holding the button till the light goes off.
Old Oct 20, 2005 | 02:38 PM
energetic's Avatar
Nice info!
Old Oct 20, 2005 | 03:05 PM
xviper's Avatar
Saved me from feeling compelled to post some smartass reply about the owner's manual.
Old Oct 20, 2005 | 04:41 PM
thetz99's Avatar
I was feeling generous today and for some reason felt compelled to save this guy from you and slows2k. Probably a karma thing
Old Oct 21, 2005 | 08:26 AM
Ogre's Avatar
Woot done
First car ever had that has 2, Maint req and Check engine. Ive usually seen them interchangeable for the standard 1.
Thanks for the help!!!
Old Oct 21, 2005 | 10:48 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Read your owner's manual,and it will "magically"disapear.!!!
TheLoons12
Aug 5, 2006 10:27 PM
blackfx35
Aug 31, 2005 04:57 PM
S2KVTEC
Sep 29, 2003 10:00 AM
newguy
Dec 21, 2002 06:09 AM
2Ting
Oct 26, 2002 07:01 AM
