rewiring horn
Old Feb 21, 2010 | 03:13 PM
rocsix's Avatar
Default rewiring horn
i have a aftermarket horn and i need to rewire it, and i need a bit more of the cable. does anyone know what kind of wire i need to splice. the cable looks very small and dont know if its splicable with any cable.
to be a bit more detailed, its the clear one where u can see the wires inside.
and where can i get it? radio shack?
Old Feb 21, 2010 | 09:04 PM
G's Avatar
G
I spliced in another wire. It was thicker than the oem wire. It has not caused any issues.
Old Feb 21, 2010 | 09:35 PM
rocsix's Avatar
ok kool. where did u get yours?
Old Feb 22, 2010 | 10:44 AM
don2007's Avatar
the "type" of wire in this case is not as important as the gauge, or size of wire. I would guess your existing wire is somewhere between 12 and 18 gauge, use 12 and you will be fine, yes radio shack carries 12 gauge wire. Also know the difference between braided wire and solid wire, braided is more flexible and can take repeated bending. Solid wire is stiff and will keep the bends you put in it, good for wire that goes in once and dosent move. Either will work for you, but I would go with braided.
Old Feb 22, 2010 | 10:46 AM
LagunaBlueAP2's Avatar
I would assume the gauge of wire is either 18 or 16.
You should be fine with 16 gauge or bigger. Radioshack, wal-mart, pepboys etc would have the wire you are looking for.
Old Feb 22, 2010 | 10:54 AM
patinum's Avatar
[media]http://www.youtube.com/watch?v=uJxWRm3_RqY [/media]
Old Feb 22, 2010 | 11:40 AM
rob-2's Avatar
If you need to pull more power through the 3A line from the stock horn you're going to blow a fuse or start a fire.
Get 16 or 18g wire and use a relay.
This will help you figure out a safe way to draw the additional power.
https://www.s2ki.com/forums/index.ph...f=193&t=766053
Old Feb 22, 2010 | 12:15 PM
rocsix's Avatar
ok thanks guys.
im also trying to removing my wheel hub but the damn thing wont unscrew!!
havent tried the steering wheel remover but the damn ratchet doesnt not work
Ajjra
Sep 28, 2009 04:17 AM
sbrodacz
Mar 22, 2009 04:07 PM
Forcedbird
Dec 4, 2008 07:30 PM
Will
Mar 2, 2006 09:00 AM
S2000_Hokie
Jun 20, 2001 01:12 PM
