Roof Leak
Old May 20, 2009 | 07:47 AM
winter5470's Avatar
Default Roof Leak
I have a (new to me) 2006 S2000. The roof just started to leak - 2 times during a heavy rain. The leak was at the first hinge joint (middle of the window) on the driver side. The funny thing is - it did not leak during the rain. I opened the door and no water leaked in. I got in, closed the door and it started leaking at the first joint joint - a steady drip for 1-2 min. The seals look good. It happened again later the same day. It has not happened again in 24 hours. Any thoughts? Can you use aerospace 303 or is a silicon lube best for the seals?
Thanks
Kurt
Old May 20, 2009 | 08:36 AM
thomsbrain's Avatar
My experience is that the seals will leak a little drip even with silicon paste lube. It's a convertible. I just run the A/C if I drive it in the rain to dehumidify, or top down if it is sunny again.
Si2k
Aug 11, 2017 12:19 AM
bikky
Oct 10, 2014 10:38 PM
revhi
May 26, 2009 12:21 PM
Fatbloke
Feb 10, 2009 02:01 PM
chw6922
Nov 13, 2006 07:44 AM
