S2000 engine replacement cost
Old Jan 10, 2001 | 09:22 AM
SkipX's Avatar
I was at Crown Honda in Chapel Hill, NC visiting a friend. I obsevered an S2K having its engine replaced after being damaged. Appearently the owner had something hit and broke the drain plug loose from the radiator and the cooling system lost all the fluid. From what I could gather, they continued to drive out of necessity and destroyed the engine.
Dealer Cost for engine ~$7500.00
Complete Repair: ~$11,500.00
FWIW: 4 new replacement engines are availible in Atlanta, GA at the time of this post.
Old Jan 10, 2001 | 06:31 PM
S TWO K's Avatar
Nuts!!!!
I didn't know they were that expensive.
From what I remember, thats as much as a M3 motor.
Old Jan 11, 2001 | 09:57 AM
Barry in Wyoming's Avatar
How does that break down?
I know there is no part number for "new engine," only "short block" (bottom including cylinders, pistons, crank shaft, etc.) and what ever the top half is called which includes cylinder heads and valves.
When you say they have "four engines," what do you mean? Do you mean four short blocks?
Barry '01 #52 650 miles
waiting for replacement short block
Chrisn01
Jul 29, 2015 10:55 AM
yan
Mar 24, 2009 09:56 AM
S2000Research
May 12, 2007 10:20 AM
dv34021
Nov 6, 2003 08:44 PM
Honda-S2000VTec
Jul 22, 2003 06:07 AM
