S2000 tows like a champ!
Old May 27, 2009 | 06:54 PM
  #251
mikegarrison's Avatar
Gernby, the advantage of the Chase hitch is that it is mounted to solid frame structure. The Da'Lan hitch mounts to thin sheetmetal in the trunk pan. Lots of history shows that those trunk pan hitches fail due to metal fatigue.
The Chase hitch is not only stronger, but it also has the advantage of being removeable.
Old May 27, 2009 | 07:20 PM
  #252
s2k aok's Avatar
i used to do that with my supercharged 2000 celica gts, mine however was a jet ski though. looked funny as hell smoking people off stoplights with a lowered celica with a thousand pound trailer (killed my power-weight ratio). the hitch had to come out and then up four inches 'cause of the height. the boat landings i went to were a lot steeper and i would't get my car wet at all though.
Old May 27, 2009 | 07:34 PM
  #253
Jim21680's Avatar
Hmmm. Now, I have seen everything.
Old May 27, 2009 | 07:51 PM
  #254
JetpilotDXB's Avatar
No...you haven't seen everything till you've seen my Chase Race hitch carrying my wakeboard, bike, and snowboard!
Old May 28, 2009 | 05:21 AM
  #255
AngryTurtle's Avatar
Dude, your wing has shoes on it.
Old May 28, 2009 | 05:38 AM
  #256
Gernby's Avatar
Former Sponsor
I'll admit that I haven't seen the design of the Chase hitch (since I've been out of the S2000 world for 3+ years), but I believe the metal fatique issue with the trunk pan was due to people having too little tongue weight. If the tongue weight is too small, then the trailer winds up pulling UP on the hitch too much over bumps, which winds up pulling DOWN on the trunk pan. This was a particular problem for the 1st generation Da'Lan hitch that only had 2 bolts attaching the front part of the hitch to the trunk pan with small fender washers. When they went to 4 bolts with larger fender washers, I believe that problem went away completely. There were no signs of metal fatigue in my trunk pan when I sold it.
Old May 28, 2009 | 06:17 AM
  #257
CitadelBlue's Avatar
I do think that expanding luggage carrying capability should be a factor as well ... especially when you travel with a +1 .....
Expanding your limitation
Old May 28, 2009 | 12:54 PM
  #258
GNN60GT500's Avatar
this is why I bought my car new...lol
Old May 28, 2009 | 07:34 PM
  #259
GateCrasher's Avatar
Thats impressive that it can be done!!
I wouldn't do it with my S but if this question comes up i will know the answer!!
Old May 28, 2009 | 08:33 PM
  #260
alz0rz's Avatar
What a great read. From start to finish.
For anyone reading this now, the OP no longer has the S2000.. traded it in long ago.
