Shifting Gears
Old Jul 28, 2004 | 10:23 AM
Tworks's Avatar
Default Shifting Gears
Hi SK2 Owners! Yeah I
Old Jul 28, 2004 | 11:55 AM
hpark's Avatar
[QUOTE=Tworks,Jul 28 2004, 10:23 AM] Hi SK2 Owners! Yeah I
Old Jul 29, 2004 | 12:21 AM
Tworks's Avatar
I seem to notice it when I start driving , the engine temp lite is 3 bars, shitting at 3000 rpm -/+ 100 rpm
Old Jul 29, 2004 | 05:22 AM
apex2k's Avatar
Not too unusual, really. Many here feel the S tranny shifts better in the higher rpm range and after it is well-warmed. Try this and also make sure the clutch is staying fully depressed the whole time (don't scoff, many admit to being in a bit of a rush and grinding). If this doesn't improve your shifting you could change out the tranny fluid. Beyond that, don't skip gears for the good of your synchros and give them a little time to do their job.
Transmission oils:
"Track review of GM Synchromesh FRICTION MODIFIED":
http://forums.s2ki.com/forums/showthread.p...threadid=182485
"what is the best transmission fluid for a s2k":
http://forums.s2ki.com/forums/showthread.p...582#post3635582
"Just switched to Penzoil Syncromesh in tranny...":
http://forums.s2ki.com/forums/showthread.p...threadid=192816
"Neo, GM syncromesh, Redline...":
http://forums.s2ki.com/forums/showthread.p...threadid=183701
"I have found the Honda MTF specification...Nedd Aussie/Brit Help!":
http://forums.s2ki.com/forums/showthread.p...threadid=199972
"AC Delco Syncromesh Manual Transmission Fluid (Friction Modified)":
http://forums.s2ki.com/forums/showthread.p...&postid=4133672
Good luck and enjoy.
Old Jul 30, 2004 | 12:31 AM
Tworks's Avatar
Post
Thanks for the Tip. I'll also check into changing the Oil in the Tyranny, being I got a nice road trip to Grand Canyon's coming up next month.
Old Jul 30, 2004 | 03:46 AM
808style's Avatar
damn dude if your shitting at 3000 rpm i have a solution for you, lay off the taco bell! j/k i couldn't resist. i too have had the notchy feeling in 3rd gear even when the car was fully warmed up. missed a couple of shifts because of it. however, the notchiness hasn't appeared ever since i changed the tranny fluid. maybe you should try that out.
Old Jul 30, 2004 | 06:01 AM
catfish's Avatar
another possible issue might be that you're cutting straight across from 2nd gear, to 3rd gear, rather than going from 2nd, straight up to N, and then let the stick 'float' on it's own to its natural center, right below 3rd. It's really really easy to do while you're getting used to the new gearbox. I find myself doing it every now and then when I rush a shift...
Enjoy your new S!!
Old Jul 31, 2004 | 12:09 AM
Tworks's Avatar
Thanks for tips Guys.Gona try changing the tyranny fluid and see whats up. Yeah and I'll cut down on my Taco Bell runs too.
Diz
Sep 20, 2010 08:59 PM
s2k_mh
Dec 13, 2009 05:10 PM
dopesilverstone
Sep 18, 2009 11:11 PM
00blackap1
Sep 30, 2008 04:13 AM
BowlofRice
Apr 10, 2007 05:41 PM
