Shifting Issues
Old May 3, 2004 | 09:55 PM
  #21
dut's Avatar
dut
Originally posted by bkern
I thought power shifting was shifting without using the clutch and speed shifting was shifting without letting off on the gas.
- thats what I was wondering...
- I thought there were a few different terms... I use the word "speedshifting" also..
Old May 3, 2004 | 10:04 PM
  #22
gswetsky's Avatar
Originally posted by Johnny--2K
Where can I get more info on the pushrod thing?
What do you want to know? The push rod is between the pedal and the clutch master cylinder. There is a specific method for adjusting it. If you take out all the free play like the person who posted above, you are asking that pressure be applied to the release bearing all the time. This is good for auto parts people who sell clutches, but not for people who have no idea what they're doing and have more money than brains!!
Gerry
Old May 4, 2004 | 03:25 AM
  #23
QIKSILVR's Avatar
[QUOTE]Originally posted by Friday03
They gave me a copy of a technical service bulletin from Honda saying this is normal on the 1-2 and 2-3 shifts when the gearbox is cold.
Old May 7, 2004 | 07:03 AM
  #24
p0pe's Avatar
I started shifting from
1->2 @ 15 mph
2->3 @ 25 mph
3->4 @ 40 mph
like the owner's manual says and the shifts are much smoother. I'm prob. gonna change tran/diff fluids and see if that helps too.
Old May 7, 2004 | 08:05 AM
  #25
cyber_x's Avatar
Originally posted by BlueMaxAaron
Since the car was a CPO car, I took it to the dealership and had them look at it, but without surprise, the service manager who drove it was unable to notice the issue or re-create the problem.
I've been going through a somewhat similar situation (it's still ongoing), and if your issue is anything like mine, then I believe there's both a driver / shifting style component as well as a "something wrong with the car" component.
On my stock '02 car, I was able to shift from 1->2 without issue until the car hit maybe 56k miles. After that, both 1st and 2nd gear became a lot more difficult to engage (it was hard to push the stick in), and the 1->2 shift was particularly bitchy. However, several other people have driven my car, and didn't notice the same difficulties. I wouldn't have believed them had I not seen it with my own eyes.
I always figured something was up with my tranny, but now I wonder about the clutch system as well. Does your clutch feel funny at all? Is it stiffer compared to other S2000 clutches? My clutch felt like crap around the time this stuff started happening, and is currently getting a new master and slave cylinder put in. I'll know the results in a few days...
In my case, changing the tranny fluid with Honda MTF didn't help at all. But, changing the clutch fluid did help for a few days, which indicated that the clutch system might play a role.
Old May 7, 2004 | 08:20 AM
  #26
gswetsky's Avatar
1->2 @ 15 mph
2->3 @ 25 mph
3->4 @ 40 mph
Just keep your rpm's above 3,000 at all times and you'll be fine.
Gerry
Old May 7, 2004 | 11:15 AM
  #27
BlueMaxAaron's Avatar
Originally posted by SilverKnight
So how does this grinding noise sound like?? When I had my 300zxTT they were notorious for gear grinds espicially in 5th. I mean you shift to 5th and get this like awful grinding sound. No such sounds on my s2k. The shifting just feels so perfect and natural. I'm sure that lil clunk sound is normal.
The grinding is definitely the teeth grinding... When it's cold and I'm shifting easy and slow, I feel the notchiness as well, but they slide in no problem, without the actual grind. The only time I get the grind is when I really shift fast, and only 1-2. Every other gear can take the speed of my shifting, just not the 1-2.
Old May 7, 2004 | 03:52 PM
  #28
Road Rage's Avatar
[QUOTE]Originally posted by Nate03
sonic9
Aug 6, 2013 10:09 PM
preeeeluuude
Oct 17, 2006 07:31 PM
XLeezardx
Jun 14, 2005 09:52 AM
Driv300mph
Sep 4, 2004 05:38 AM
bbsilver
Oct 31, 2000 09:47 AM
