Starter motor not functioning
Old May 9, 2025 | 04:42 AM
Car Analogy's Avatar
Originally Posted by MM53
I have checked the connection to the starter solenoid and there is no power on the solenoid cable when the starter button is pressed with ign on.
That sounds like something aftermarket impeding the srarter solenoid signal. Like an alarm, or a hidden security switch to start car, or a remote disable device, etc.
Old May 10, 2025 | 12:11 AM
MM53's Avatar
I have an alarm system fitted so I will it out. Thanks
Old May 10, 2025 | 12:13 AM
MM53's Avatar
Check it out I meant
Old May 11, 2025 | 12:56 PM
MM53's Avatar
Bingo, found it. It was the alarm system that was causing the issue. I fiddled with the alarm fuses and wiring and then had a cranking feed to the starter solenoid. I will spend more time now to identify exactly which wire was causing the problem.
Thank you Car Analogy for the heads up on the alarm and to everyone who has contributed to this thread. Cheers
Old May 11, 2025 | 02:16 PM
Glad you found it!
will_r
Sep 9, 2022 06:32 AM
crank
May 16, 2019 07:23 PM
glenstrum
Dec 16, 2013 11:20 AM
armas2k
Mar 7, 2011 05:39 PM
armas2k
Mar 7, 2011 05:08 PM
