Stop the morning shakes...
I've heard that you should aslwaya use the Honda oil for the S@K because it has some sort of specail ingredient that does make it perform better.
Is it safe to replace with synthetic oil? Can someone with knowledge comment please?
Thanks
Thanks
[QUOTE]Originally posted by LostWaffle
[B]I've heard that you should aslwaya use the Honda oil for the S@K because it has some sort of specail ingredient that does make it perform better.
I have used Castrol GTX 10W-30 forever on my cars including the S and never had a single problem.
However, after doing a lot of research (i.e., http://pacific.telebyte.com/allanw/binder/...nfo/oilfaq.html )I thought
For people who live in the cooler climates, use 5w instead of 10w and it should make a little difference. I didn't have that big of an issue, but here in missouri lately it has been pretty cold, and I tried out 5w and noticed a difference. I agree with DouglaS2000 when he says synthetic or not. If you change every 3k you shouldnt worry if it is synthetic or not, but the cold weather recommends a little different weight is all.
