Tein S-tech spring rate
Old May 20, 2007 | 08:57 AM
iluvs2ks's Avatar
Default Tein S-tech spring rate
Ok can be a stupid question but i dont got alot of knowledge on this topic. Ok I got a set of Tein S-tech springs from a 2000 prelude. They will fit the s2000 but the difference between prelude and s2000 springs are the spring rates. here are the spring rates:
s2000:
FRONT:
kgf/mm lbs/in Drop
5.3 300 -1.02
REAR:
kgf/mm lbs/in Drop
6.5 360 -0.98
Prelude
FRONT:
kgf/mm lbs/in Drop
4.3 240 -1.46
REAR:
kgf/mm lbs/in Drop
3.7 210 -1.34
Someone if you can please give me a some info on spring rates and tell me something about these numbers... Any feedback is greatly appreciated
Old May 20, 2007 | 11:14 AM
kamui157's Avatar
Stock 2004 Spring rates:
Fr: 233(4.16) - Rr: 262(4.68)
Essentially, if you install those, your ride will be softer than stock in the rear, inducing more understeer.
Old May 20, 2007 | 12:18 PM
f23power's Avatar
granted the prelude springs may fit the strut body on the s2000...why put them on? is the $50 your saving by putting on used springs designed for a completely different platform really worth risking on a 30k+dollar car?
-a
Old May 20, 2007 | 05:24 PM
iluvs2ks's Avatar
you do have a point
Old May 20, 2007 | 05:38 PM
donger274's Avatar
if your going with springs you might as well buy a set of springs for the right car
if you can fit coilovers than maybe haha
Old May 21, 2007 | 12:43 PM
Boofster's Avatar
Those Prelude spring rates are way too low. Pass on it.
A new set of S.Tech's is under $200.
bluemetals2k
Jan 24, 2011 03:29 PM
bluemetals2k
Jan 23, 2011 07:56 PM
WyattH
Jul 14, 2009 12:38 PM
rotorman7
Feb 15, 2009 10:46 AM
f23power
Mar 17, 2008 04:05 PM
