Temporary Spare Question
I need to have my rear left wheel repaired and I plan to remove it and cart it over the shop and leave my S2000 in the garage. I would like to put the temporary spare tire in the left rear position so I don't have to leave the car on a jack for an extended period of time.
I know I'm not supposed to do this due to possible damage to the rear differential, but if I don't drive or otherwise move the S2000, is there any damage that can occur? Or should I just move the front to the rear and put the spare in the front?
From: All up in your inner tubes. Whatcha gonna do sucka?
there shouldn't be any problems.
then again, I was in a hurry when I had a nail in my rear tire, and it slipped my mind about putting the spare on the rear wheel. I drove it lightly for about 5 miles at 30mph or less, and my rear diff is still fine.
I believe it does 'damage' to the rear diff due to the type of diff we have. we have the torsen geared diff, so if we have mismatched sizes of rear tires it 'binds' and always tries to give the wheels same amount of torque = one side dragging/one side pulling
correct me if im wrong, someone
-edit-
forgot to anwer your question:
so basically, setting it on the rear without moving the car shouldnt damage the diff @ all..
-edit-
Originally Posted by dparm,Oct 15 2008, 09:09 PM
It is fine for short-term use, hence the term "temporary spare".
I don't think you will cause damage with minimal use, but it's so simple to make the appropriate swap, I would be inclined to do it before moving. If you're just sitting in the driveway, don't waste your time.
I'm fairly certain while it may easily cause damage, honda has that statement as a fail-safe for idiots who might drive the car normal while the spare is on the back.
I've heard of and read stories about people messing up their diff, tho. I guess I was lucky
Deleted03.15
Jul 16, 2014 04:31 AM
leaving it in the garage shouldn't do anything at all to your diff...
