Temporary Spare Question
Old Oct 15, 2008 | 12:35 PM
protmind's Avatar
Default Temporary Spare Question
I need to have my rear left wheel repaired and I plan to remove it and cart it over the shop and leave my S2000 in the garage. I would like to put the temporary spare tire in the left rear position so I don't have to leave the car on a jack for an extended period of time.
I know I'm not supposed to do this due to possible damage to the rear differential, but if I don't drive or otherwise move the S2000, is there any damage that can occur? Or should I just move the front to the rear and put the spare in the front?
Old Oct 15, 2008 | 12:49 PM
senor_flojo's Avatar
From: All up in your inner tubes. Whatcha gonna do sucka?
there shouldn't be any problems.
then again, I was in a hurry when I had a nail in my rear tire, and it slipped my mind about putting the spare on the rear wheel. I drove it lightly for about 5 miles at 30mph or less, and my rear diff is still fine.
Old Oct 15, 2008 | 12:53 PM
thebig33tuna's Avatar
i drove for almost a week with mine on the rear with no problems. that was... 10 or 15k miles ago?
leaving it in the garage shouldn't do anything at all to your diff...
Old Oct 15, 2008 | 01:12 PM
common reactor's Avatar
Mine was lowered too much to use it
Old Oct 15, 2008 | 02:00 PM
ahrmike's Avatar
I believe it does 'damage' to the rear diff due to the type of diff we have. we have the torsen geared diff, so if we have mismatched sizes of rear tires it 'binds' and always tries to give the wheels same amount of torque = one side dragging/one side pulling
correct me if im wrong, someone
-edit-
forgot to anwer your question:
so basically, setting it on the rear without moving the car shouldnt damage the diff @ all..
Old Oct 15, 2008 | 03:07 PM
tof's Avatar
tof
You'll be fine. Just don't drive all over town or hit the Interstate with the doughnut on the rear.
Old Oct 15, 2008 | 05:09 PM
dparm's Avatar
It is fine for short-term use, hence the term "temporary spare".
Old Oct 16, 2008 | 08:47 AM
vtec9's Avatar
Honda recommends you put a front wheel and tire on the rear, and the spare on the front if you have a problem with a rear tire.
I don't think you will cause damage with minimal use, but it's so simple to make the appropriate swap, I would be inclined to do it before moving. If you're just sitting in the driveway, don't waste your time.
Old Oct 16, 2008 | 10:41 AM
you're correct. I noticed it gets a little squirrely in back when you're moving from a stop. and that was light on the throttle.
I'm fairly certain while it may easily cause damage, honda has that statement as a fail-safe for idiots who might drive the car normal while the spare is on the back.
I've heard of and read stories about people messing up their diff, tho. I guess I was lucky
Old Oct 16, 2008 | 11:01 AM
vtec9's Avatar
I think it's half because they want to limit damage to the diff, and half because a lot of drivers can't keep the rear wheels planted with 245s, much less a freakin donut.
Deleted03.15
Jul 16, 2014 04:31 AM
S2KPC
Jun 6, 2009 08:45 PM
78roadrocket
May 13, 2005 05:56 AM
RUGBY
Jan 11, 2005 03:35 AM
SteveS2K
Jul 18, 2002 10:31 AM
