Test pipes
Originally Posted by XclusiveAutosports,May 4 2006, 04:58 AM
BTW, here is what my car sounded like when it had a testpipe and an HKS...
http://videos.streetfire.net/search/s2000+...F7B0D4E46CF.htm
By the way, you need to hit the apex a little tighter on those corners!
Man I spoke too soon
. This morning when I turned on the S. Baaaaam! Check Engine light.
I called berk and they suggested I reset my ecu? I dont think that is going to fix it or the CEL probably would have come on right away. I will get an anti-fouler after work today. Hope fully that will fix it.
xviper - I pulled the back up fuse under the dash, left it out for about 2 min. after I put the fuse back in the CEL stayed on. When resetting the ECU does the key have to be in the ignition (in the off position)? I did not have the key in the ignition while the backup fuse was out.
. This morning when I turned on the S. Baaaaam! Check Engine light.I called berk and they suggested I reset my ecu? I dont think that is going to fix it or the CEL probably would have come on right away. I will get an anti-fouler after work today. Hope fully that will fix it.
It amazes me that Berk would tell you to just reset the ECU to fix something that is a design flaw with their product.
Originally Posted by xviper,May 4 2006, 01:19 PM
Are you sure it was the "BACK UP" fuse. It only needs to be out for less than 1/2 a minute and the ignition should be OFF.
Emil St-Hilaire, I was looking for another way to do it because I did not want to lose my Radio if possible, my owners manual is at home and it has my radio code in it.
About Berk
whatever. I ran to pep boys and picked up the anti-fouler, installed it real quick and ran back to work
. (crosses fingers and hopes the CEL stays off!) I guess I got one of their test pipes that was flawed
. My thinking is that once the CEL turns on it would probably come on again and I would rather fix the issue than to keep pretending its not there (resetting the ECU every 40-50 miles)Thanks for responding xviper
Ok I installed my berk TP last saturday (8 days ago). Since then I have driven 1200 miles and cycled almost 4 tanks of gas (took a 650 mile trip this weekend), and I have yet to get a CEL.. so the berk fix seems to have worked for my car.
edit: I've broken 2,000 miles with no CEL.
A Berk TP should arrive in the mail in a next few days. I am very anxious to hear how it sounds with my HKS. From the clips that I have heard...it will be very, very good.
I probably wouldn't have purchased the test pipe, but I deemed it a "necessary modification" to get the most out of the BRP SC kit.
