TSB for Clutch just completed...
Old Oct 26, 2002 | 02:52 PM
  #91
Prolene's Avatar
[QUOTE]Originally posted by j76ms
[B]....when I push my clutch in slowly and let it out slowly it sounds like opening and closing a really old squeaky door in a haunted house.
Old Oct 26, 2002 | 05:01 PM
  #92
boiler's Avatar
Originally posted by Prolene
Since there are no return springs for the clutch pedal
I thought that the return springs were way up under the dash and if memory serves me, are probably the source of the squeak. Several people have had that problem and greasing the return springs fixed the problem.
I just checked and I have a return spring just above the clutch master cylinder (under the dash, next to the firewall). I think that the spring coils were greased to fix the squeak. At any rate, climb in the car head first, then look up under the dash, next to the firewall and above the clutch master cylinder, you should be able to see the return spring. A light is a good thing to have in hand when you crawl into the car. It helps to move the clutch pedal when you are looking for the spring.
Good luck,
Bob
Old Oct 26, 2002 | 05:18 PM
  #93
Prolene's Avatar
I stand (sitting...) corrected. There is a spring at the top of the clutch pedal assembly. I might try lubing that, too, as with the slave cylinder bleed screw loosened, my pedal does not spring back after being depressed.... That's why I thought there was no spring....
Good job, Bob.
Old Oct 26, 2002 | 08:33 PM
  #94
boiler's Avatar
[QUOTE]Originally posted by Prolene
[B]I stand (sitting...) corrected.
Old Oct 27, 2002 | 03:27 AM
  #95
tripleblackS200's Avatar
Had my clutch done. It is like a brand new car. The tranny is quiet, no more Burrrrrrrr when I down shift. The best part is I got it all for free thanks to S2000 international.
Old Oct 27, 2002 | 07:41 AM
  #96
j76ms's Avatar
I would like to thank everyone for helping me out with the clutch sound. I looked inside at the clutch and pushed it a few times then had my wife push it while I was looking underneath the car. I am positive that I can hear it better from outside the car. The sound seems to come from the bottom part of the engine area where the clutch possibly comes out. I just can't find an exact spot though. Thanks again.
markpenske
Mar 2, 2010 12:12 AM
chrisjm00
Mar 27, 2008 08:00 PM
btstone84
Mar 14, 2008 10:17 AM
chanhinsaechao
Feb 4, 2008 10:41 PM
Y2KS2K02780
Dec 3, 2003 04:30 PM
