turbo
Old Jul 8, 2001 | 03:28 PM
Eze8199's Avatar
Default turbo
Is anyone ever going to come out with a turbo for the s2k? I Think I would rather have a turbo than an sc on the s2000. Thanks
Old Jul 8, 2001 | 05:51 PM
S2R's Avatar
S2R
Ben from Bulletproof is still working on it, and I think he's hoping it'll be ready in a month or two.
Old Jul 8, 2001 | 06:07 PM
Eze8199's Avatar
can you currently put some sort of custom turbo on the s2k?
Old Jul 8, 2001 | 06:22 PM
S2000yellow's Avatar
With an 11:1 compression ratio you can't run much boost, a good turbo setup would require pistons to lower the CR, an intercooler and about 17 psi, then this engine will truly rock!
Old Jul 9, 2001 | 07:07 AM
Visitor's Avatar
Originally posted by S2000yellow
With an 11:1 compression ratio you can't run much boost, a good turbo setup would require pistons to lower the CR, ..
I agree, always inquire about the compression ratio before buying a new car, that is, if you want to go turbo without tearing the stock motor apart.
15 psi Miata
Old Jul 9, 2001 | 07:30 AM
derryck's Avatar
My turbo will be done and dynoed next month and will appear in at least a couple of magzines. If the interest is there my mechanic has agreed to produce 'bolt-on' kits including the manifold. No changes are necessary to lower compression as boost will be targeted at about 6 psi. Should dyno in the 320 RWHP range and cost should not be alot higher than the Comptech SC.
Old Jul 9, 2001 | 12:15 PM
JBoggs's Avatar
[QUOTE]Originally posted by derryck
[B]My turbo will be done and dynoed next month and will appear in at least a couple of magzines.
Old Jul 9, 2001 | 12:33 PM
derryck's Avatar
I'm hoping that it will do that to the C5's not just the LS1's. My car has consistently run in the 13.6-13.8 range at Gainesville Raceway. I'm hoping that full boost will be achieved in the 3500-4000 RPM range and I won't have to thrash the drivetrain so bad to get out of the hole. I'm hoping for 'leisurely' low 13's on street tires with off idle launches.
Old Jul 9, 2001 | 02:17 PM
RxS2K's Avatar
Hey derryck, give me an e-mail when you get the car "set-up". I'm also in Gainesville, and would love to see what you're doing!
Old Jul 9, 2001 | 02:26 PM
derryck's Avatar
I'll let you know as soon as it's finished.
bjs2000
Mar 21, 2017 10:36 AM
bjs2000
Feb 17, 2017 09:25 AM
boostalmighty
Mar 2, 2010 04:15 PM
nsxinsac
Jun 22, 2005 05:03 PM
